Stock Fuel Pump/regulator Issues
Discussion in 'Performance and Tuning' started by My68ur8trd, Apr 12, 2010.
  1. Apr 12, 2010 at 9:15 AM
    My68ur8trd
    My68ur8trd [OP] Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    I just want to let you guys know what I have going to just for information to those with similar situation.
    My truck has 36K on it and was a daily driver for the last owner who seems to have ran regular fuel for its entire life.
    I put the TRD S/C with the stock pulley on it two weeks ago and the X1. When Gadget and I ran it up and down the interstate, the injectors were maxed at 95% duty cycle ( yep and this is on the stock pulley).
    Well I put my fuel pressure gauge back in yesterday and took it for a spin. Normal driving the FPR hovers around 40 PSI ( system is supposed to be 42.5, but my gauge has always read 40).
    WOT the pressure tanks to about 33[​IMG]
    So time for a URD pump upgrade. But I wanted you guys that are boosting trucks with a few more miles on them to know. Even with the stock pulley, the system is maxed if the filter is gummed up. I dont know how the TRD reflash would handle it, but the X1 does its job by increasing the DC to compensate
    Also,
    The regulator seems to be leaking too.
    I had the oddly long start ever since I got the truck. When I shut it down, the FP drops from 40 psi to 0 in about 3 seconds. Which explains it
    So I will be changing that too.
    the quirks of a used vehicle [​IMG]
    Justin
  2. Apr 12, 2010 at 11:49 AM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    Actually per Toyota -
    Standard Fuel Pressure: 281 to 287 kPa (2.87 to 2.93 kgf/cm2, 40.8 to 41.7 psi).
  3. Apr 12, 2010 at 11:59 AM
    My68ur8trd
    Justin
    Williamsburg, VA
    then the gauge isnt that far off:)
    toyota would pick a wierd non standard pressure
    Justin
  4. Apr 12, 2010 at 2:14 PM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Yep, I'd say your gauge is pretty damn accurate. Mine will sit between 38-40psi, and i've read taht there is anywhere from 1-2psi discrepancy depending on the sensor.
