Stock head, all new speakers & amp.
Discussion in 'Audio & Video' started by CantSitStill, Apr 5, 2012.
  1. Apr 5, 2012 at 4:36 PM
    CantSitStill
    CantSitStill [OP] Well-Known Member
    FTR
    CNY
    I got asked to start a thread. Hopefully this helps someone out. I wanted to keep the stock head unit in my 2012 Double Cab, but get some much better sound. I'm 37y/o now, so I'm more into good sound than shaking windows. I also like subtle mods over everyone knowing what I did.
    This is what is going in. The sound processor will change. The Audio Control unit will not work with the 2012 for some reason. I have tried two of them, and spent hours on the phone with Crutchfield tech support and Audio Controls. No one can figure why it won't work. I have the JL Cleensweep on it's way. Hopefully seeing it Monday.
  2. Apr 5, 2012 at 4:45 PM
    CantSitStill
    FTR
    CNY
    Don't forget to take off the neg terminal.
    Rear seats out, amp will go behind passenger seat, Sound Ordnance powered sub behind the driver seat.
    A little more stripping to run wires and do some sound deadening.
    Front stripped. I wanted to add outlets to the interior but my time ran out.
  3. Apr 5, 2012 at 4:53 PM
    CantSitStill
    FTR
    CNY
    Sent from Crutchfield. Might help some.
    Did some Dremel work to get the sub volume control in a switch blank.
    Found the stock speaker wires, opened the harness and got ready to extend the wires to the glovebox. This is where the line level converter will live.
    Color matched, soldered, shrink wrapped and color matched.
    Well, here WAS the install. This is what will be swapped for the JL unit. I wanted the EQ feature, but hopefully the JL unit will be as good or better.
  4. Apr 5, 2012 at 4:54 PM
    OneMentalCase
    OneMentalCase Well-Known Member
    South Florida
    10 Pyrite LB
    Sub'd :popcorn:
    Thanks for the install thread....
  5. Apr 5, 2012 at 4:57 PM
    CantSitStill
    FTR
    CNY
    For the rears.
    Front
    That's a Lot of wires. A pretty tight fit. I actually had to use both the driver and passenger channels for 3 RCAs, four 14g speaker wire pairs, remote wire, sub control, and two power wires.
  6. Apr 5, 2012 at 4:58 PM
    CantSitStill
    FTR
    CNY
    No problem!!! Hope it helps you.
  7. Apr 5, 2012 at 5:21 PM
    CantSitStill
    FTR
    CNY
    So, until Monday when my new line processor gets here, this is my source of tunes! HAH! It works though.
  8. Apr 5, 2012 at 5:22 PM
    CantSitStill
    FTR
    CNY
    Oops, forgot the pic.
  9. Apr 5, 2012 at 5:25 PM
    CantSitStill
    FTR
    CNY
    That foam that you see around the head unit is what I have been using in the doors and panels. Sound Foam. I got a huge box of it about 12 years ago, and have used it in a bunch of installs and it works great.
  10. Apr 5, 2012 at 6:28 PM
    tango down
    tango down Policy Ninja
    jeff
    peoples republik of IL
    12 Taco DCSB TRD Off Road
    LED interior, rail mounted ammo cans
    wow, great thread. i was going to ask last night if it was possible to add an amp to the factory h/u. I dont feel like having to lose my steering wheel control, or pay again to have them back after a h/u upgrade.
    I didnt even think of the sound processor as being a way to add aftermarket stuff to the facto h.u.
    well done.
  11. Apr 5, 2012 at 7:11 PM
    CantSitStill
    FTR
    CNY
    Thanks, I'll post up after the JL
    unit gets installed. Hopefully it comes Monday and I get time that night. Hoping the signal is nice and clean. Don't want any noise other than the noises I want!
  12. Apr 5, 2012 at 8:40 PM
    Desert Snow
    Desert Snow Well-Known Member
    Greg
    Chandler, AZ
    2012 4x4 DCSB Pyrite Mica
    Bilstein 5100s, 1" blocks rear, ATX Slot Chrome 17x8, Toyo Open Country 285/70/17s, Polished N-Fab steps, Pioneer AVH-P4400BH, Alpine PDX-V9, Boston Acoustics Pro60SE front, Boston Acoustics SR65 rear, ID 10D4v.3 sub, SuperCrew sub box, RaamAudio sound deadener, Escort 9500ix with BlendMount, shorty antenna, tint
    Did you look at the Rockford Fosgate 3Sixty.3 or JBL MS-8 as alternatives to the Clean Sweep? Friend of a friend is a RF factory rep and he's high on the 3Sixty but would like a more "unbiased" perspective.
  13. Apr 6, 2012 at 3:24 AM
    CantSitStill
    FTR
    CNY
    Too much money for me to look at. Those are around $700-$800 each. The Audio Control unit was $240 and the JL is $300. I have about $1100 into this entire setup. I just didn't want to be building another $2000-$3000 system.
  14. Apr 6, 2012 at 8:24 AM
    Desert Snow
    Greg
    Chandler, AZ
    I hear you. Wife already has issues with the lift, wheels/tires. Will only do the RF unit if my contact gives a killer deal.
    Let us know how the Clean Sweep sounds and integrates with the steering controls and bluetooth. You planning to use the volume control or just use the HU controls?
  15. Apr 6, 2012 at 10:54 AM
    CantSitStill
    FTR
    CNY
    I'm hoping to use the head unit since I already put the sub volume control in dash. Seems crazy- volume on head, volume for sub, volume for CleenSweep. We'll see how it goes.
  16. Apr 9, 2012 at 5:37 PM
    CantSitStill
    FTR
    CNY
    So, it works! It's just jumped in right now, but it works! I was really concerned I was going to have to upgrade the head unit after the fiasco with the Audio Control unit.
    After reading the instructions for the JL Clernsweep, I decided to use their volume control for the best sound quality. This location seemed to be great for easy access and the LED is right there too.
    I need to spend some time find tuning, but I am really impressed with the sound. I can get the volume higher than I am able to listen to without my head throbbing before distortion kicks in. Pretty much just what I was looking for. I think the Sound Ordnance 8" sub is going to be just fine after all the tuning is done.
  17. Apr 9, 2012 at 5:42 PM
    CantSitStill
    FTR
    CNY
    Sorry, iPhone issues. Lots of typos.
    It's "Cleensweep" and "fine tuning"
  18. Apr 10, 2012 at 5:47 AM
    Tommy
    Tommy Well-Known Member
    Tom
    Indiana
    2010 Access cab SR5 4x4
    glad to hear the sound ordnance sub sounds good, I'm getting ready to install one today or tomarrow. I'm curious to see the settings on the sub that you come up with after tuning if you wouldn't mind.
  19. Apr 10, 2012 at 11:34 AM
    CantSitStill
    FTR
    CNY
    Will do.
  20. Apr 11, 2012 at 7:27 AM
    Krewblink
    Krewblink Well-Known Member
    Danny
    Long Beach
    05 toyo Prerunner
    Exhaust,Seat Covers, Intake
    Can u make a video of how the sound ordinance sub sounds like? I want to get one.. But.. Having second thoughts...
