Stock head Unit With a sound processor
Discussion in 'Audio & Video' started by Winger12003, Mar 1, 2012.
  1. Mar 1, 2012 at 5:00 PM
    Winger12003
    Winger12003 [OP] Well-Known Member
    Elizabeth City, NC
    2012 TRD OFFROAD 4x4
    265/75/16 Duratracs, 1.25 Spidertrax, OEM rack, TRD catback, weathertechs, TRD bead Locks, 5100's all around with 1 inch rear block
    Does anyone know if you use a sound processor like the JL Clean sweep if you can still use the steering wheel volume controls? Also does it affect the use of the stock head units Bluetooth? I thought read in the audio information section that using your steering wheel volume controls would over ride the signal processor.
  2. Mar 1, 2012 at 6:57 PM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    The issue is with factory units having a volume based EQ. If they do not (flat response, top to bottom), then there is generally no issue. If your head unit makes changes based on volume, you need to use the volume on the processor, leaving the factory head unit in the same volume position you set things up with.
