Stock headlights + led offroad lights?
Discussion in 'Lighting' started by evile, Aug 18, 2014.
  1. Aug 18, 2014 at 11:44 AM
    evile
    evile [OP] Well-Known Member
    Orlando, Fl
    2006 DoubleCab TRD OffRoad PreRunner
    Bug shield vent visors Westin Chrome bull bar K&N Airfilter Pioneer CD/MP3/Ipod/DVD head unit KC Daylighters, LED map and dome lights, secondary airfilter removed. Black tube steps, 110v outlet in cab
    A question for those with led offroad lights. Do you run the stock halogen bulbs with a led lightbar? I'd like to get a light bar but kinda worried it will look goofy with regular bulbs and the led lights
  2. Aug 18, 2014 at 11:46 AM
    Large
    Large Red
  3. Aug 18, 2014 at 11:47 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    :confused: x2
    Are you asking if they replace their halogen bulbs in the stock headlamps with LED bulbs to match the LED light bars? Because otherwise mixing halogen stocks with LED aftermarkets looks weird?
  4. Aug 18, 2014 at 11:48 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    If you're throwing all that light downrange who cares what it looks like? Shouldn't be shining it at oncoming traffic and the light bar will likely flood out your headlights.
  5. Aug 18, 2014 at 11:49 AM
    evile
    Orlando, Fl
    Pretty much. Be it replacing with led or hid. Can't find any pictures that show the halogen head lights with an led bar at night
  6. Aug 18, 2014 at 11:49 AM
    T4RFTMFW
    If that's the question, I wouldn't overthink it so much. If you want them to match, get LED headlight lamps. Only the road will see your lamps, and a few critters somewhere, and they wont care if you have halogen headlamps and LED bars.
    If you can afford to match all your light sources, go for it. If not, I think the only one who it will bother is you!
  7. Aug 18, 2014 at 11:51 AM
    T4RFTMFW
    Meh, I'm sure there's a lot of them on TW. Not everybody runs HID headlamps and even less people have LED lamps in their stock housings. I'd just buy the lightbar and install it, and if it bugs you that they mismatch then you can buy better halogen bulbs, upgrade to HID or LED and call it a day. It's really limited to what YOU want your truck to look like, nobody else will give it a second thought in this case, I dont think
  8. Aug 18, 2014 at 11:54 AM
    Large
    Large Red
    I run halogen with LED bars / duallies. Works like a damn charm
  9. Aug 18, 2014 at 12:34 PM
    evile
    Orlando, Fl
    Possible to get a night time shot? I'm looking at a led bar on Amazon has spots on the outer And a flood in the center. Do you need two switches to operate them?
  10. Aug 18, 2014 at 12:36 PM
    T4RFTMFW
    Believe all the dual mode bars are single switch and the spot/flood runs simultaneously.
  11. Aug 18, 2014 at 12:41 PM
    SteveO86
    SteveO86 Well-Known Member
    South Korea
    2013 Super White TRD Sport DCSB 4x4 (Sold)
    BHLM w/ Retrofit, Window Tint, xB LED Fogs, Rigid Dually D2s w/ Amber Covers, Matt123 Skid & Tow Hook, Cobra 75 CB w/ 3' Firestik on BAMF mount, N-Fab Steps, Tonneau, Scangauge II, AVID Light Bar, Katzkin Seats, Remote Starter
    I don't see why halogen headlights would be a problem with a LED bar. I upgraded my headlights to HID via retrofit because I like the output from HIDs. I also swapped my factory fogs to the TRS xB LED kit.
    As far as the color difference goes, I have amber lenses on my duallys to help cut through dusty/snowy conditions. Compare that that to white of the HIDs and fogs.
    Here is an output shot with the HIDs, LED Fogs, and Rigid Dually's (Before I installed the covers) on.
    Here is a shot of the truck with everything on at night
    Finally, a daytime shot of where I have everything mounted.
