STOCK HEIGHT RIMS & TIRES PACKAGE??
Discussion in 'Wheels & Tires' started by sockittome, Jul 18, 2012.
  1. Jul 18, 2012 at 7:26 AM
    sockittome
    sockittome [OP] Member
    Hello there does anyone know what offset & backspace rims I should buy. I am interested in the Ballistic Jesters. The tires I bought are 265/70/17. I'm a stock height 07 2wd double cab , thanx.
  2. Jul 18, 2012 at 5:20 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Anywhere between 5.5 and 4.5" backspacing. And make sure the tires you bought are approved for 9" wide wheels, which is all the jesters come in. You can check on the tire manufacturers website.
  3. Jul 19, 2012 at 7:03 AM
    sockittome
    I appreciate the info. Would you happen to know if the offset is better to be bought in +12, -12, or 0? Also will these fit without a lift with 265/70/17 without mods?
  4. Jul 19, 2012 at 7:10 AM
    TexasTacoma37
    If you never plan to fun 285's, I'd go with the 0. Some folks have had slight rubbing on the -12 with no lift, even with 265's.
    If you plan to go to 285's one day, get the -12.
  5. Jul 19, 2012 at 8:04 PM
    lefthand6
    lefthand6 Member
    Mal
    Seattle/North Bend/Snoqualmie Valley
    PreRunner V6
    Hey, I think you made a typo. If he plans on doing the 285s should he do -12, or +12? You said -12 folks have rubbing with 285s, but that he was planning on doing 285s one day he should get -12?
  6. Jul 19, 2012 at 9:11 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    285s in the future, go with -12 offset. going with +12 is going to push the wheels inward and you might end up rubbing on the uca with a wide tire.
  7. Jul 19, 2012 at 11:28 PM
    sockittome
    Thanks again! I was thinking maybe a 3" lift.
  8. Jul 20, 2012 at 5:53 AM
    TexasTacoma37
    I said some -12 folks have rubbing with the 265's, at stock height. -12 is ideal for 285's with 3" of lift though (still some rubbing though).
    +12 or zero is fine for 265's.
  9. Jul 20, 2012 at 10:30 AM
    lefthand6
    lefthand6 Member
    Mal
    PreRunner V6
    Gotcha, thanks for clarifying.
  10. Jul 22, 2012 at 2:46 AM
    sockittome
    So after long thinking this out I want to stay at stock height keep my 265/70/17's but which offset will be best not to rub +12 or 0? i dont plan on lifting or ever go with 285"s. By the way I like your SCS logo, Im in the Bay Area too.
  11. Jul 22, 2012 at 5:04 AM
    TexasTacoma37
    Doesn't matter, both with work. The 0 will stick out a half inch more than the +12
  12. Jul 22, 2012 at 9:41 AM
    sockittome
    Thank you KPT, your the man.
  13. Jul 23, 2012 at 12:58 AM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    Keith knows his wheels. Both offset will work with 265s. Between +12 and 0, I would choose 0 just to push the wheel out a little.
    If you would like a free SCS decal, let me know:D. I have a bunch of different colors to choose from.
  14. Jul 23, 2012 at 7:19 AM
    sockittome
    Thank you!
  15. Jul 23, 2012 at 10:58 AM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    Randy, I got your message. Not sure if you know, but you've set your account not to receive PMs. I will send them out to you soon;).
  16. Jul 24, 2012 at 6:54 AM
    sockittome
    I will change that ASAP, thanks.
