Stock height + stock factory tire OD + 0 offset
Discussion in 'Wheels & Tires' started by mwr5, Sep 6, 2022.
  1. Sep 6, 2022 at 5:54 PM
    mwr5
    mwr5 [OP] New Member
    Ray
    19 TRD Sport
    I've been looking all over TW for someone with the exact set-up below and wanted to know if you get any rub (full turn and at an angle is probably worse case interference)
    265/65/R17 OR 265/70/R16 on stock height and 0 offset.
    I've seen many people say there is slight rub on inclines/declines at full turn with the same offset but +1" tire size, but wanted to know what's out there keeping the factory OD. I don't see the offset changing from +30 to 0 causing significant rub but wanted to be sure before pulling the trigger on new wheels.
  2. Sep 7, 2022 at 5:51 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Going from +30 to 0 is an 1 1/4”. You should be fine with the tire sizes of choice. Just get an alignment and have the tech set the caster at the higher end of the range.
  3. Sep 7, 2022 at 10:02 PM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    stock size tire at 0 offset = no rub whatsoever
    I've put 16x8 and 18x9 wheels on my Tacoma with 0 offset keeping tire stock, no rub under any circumstance
