Stock Hieght First Gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by Anthony250, Jul 6, 2011.
  1. Jul 6, 2011 at 10:28 AM
    Anthony250
    Anthony250 [OP] Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Well when i first bought my truck it came with sport rims 17"s and then i lifted spacer lift and i dont have old measurements. Now i have 16" rims with 265/75/16 tires. And i got coilovers up front and got add a leaf out back that gave me 2 inches of lift from stock rear. But i want to know your stock hieghts so i know how much lift im getting up front. I feel like maybe i cranked the coilovers alot, and i have no idea how much height im getting since i dont have stock numbers.So if you stock guys or others too tell me the size between the center of the top of fender. I have no fender flares so im guessing thats a inch or so less removed. Or a measurment from floor to Toyota logo on grill. Thanks guys ,
  2. Jul 6, 2011 at 10:52 AM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    The only way you can know for sure where you are in relation to a new, stock truck is by measuring ride height per the FSM.
    I've attached that info. You need to find your truck's code on the door jamb sticker where the VIN is. It will be something like:
    RZN140L–TRMDKAB
    Find this, then refer to the spec sheet, then measure your height. It is the difference between the hub height and the LCA front bolt center (front height), and for the rear, the front main eye bolt on the leaf and the rear hub.
    Another FSM page shows these measurement points, but I do not have that handy at the moment.
    EDIT: I've attached SA-10, which shows the measurement points.
    BTW, the spec height assumes stock tire size for the given model...so that is a factor too.
  3. Sep 13, 2011 at 8:33 PM
    Anthony250
    Anthony
    San Gabriel Ca
    anybody give me some hieghts?
    To make it easier from floor, to bottom of door. And what size tires.
    Thanks
  4. Sep 13, 2011 at 8:53 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Scott, that gave me a headache. :p
    Anthony, I have measurements from before lift. Not sure of their value to you because there was some sag going on from the stock TRD coils. FWIW, from center wheel hub to bottom of fender flair was 21.125" driver and 21.25" passenger.
  5. Sep 13, 2011 at 9:29 PM
    Anthony250
    Anthony
    San Gabriel Ca
    Thanks, but i have fiberglass fenders now. LOL. Probably switching to 650 coils too,
  6. Sep 13, 2011 at 11:13 PM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    What can I say. I went overboard trying to figure out how to level my worn-out suspension...
  7. Sep 13, 2011 at 11:16 PM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    What Mike said is how most people measure this, so you'll have to wait for some motivated stocker owner to go take special measurements for you.
    :popcorn:
  8. Sep 13, 2011 at 11:18 PM
    Anthony250
    Anthony
    San Gabriel Ca
    Or even others with 3" lifts. Measurements from Floor to bottom of door,
  9. Sep 14, 2011 at 7:43 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Why not just carry a tape measure with you. When you spot a stocker in some random parking lot, go grab a measurement off of it. :rolleyes:
  10. Sep 14, 2011 at 9:40 AM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    How can you be that smart and not understand my post? Hmmm. :D
  11. Sep 14, 2011 at 9:59 AM
    Anthony250
    Anthony
    San Gabriel Ca
    Cause im lazy lol, are you racerunners leaking? LOL
  12. Sep 14, 2011 at 10:07 AM
    Digiratus
    Roaming the PNW
    The RedHead
    :anonymous:
    No. Why?
  13. Sep 14, 2011 at 10:17 AM
    Anthony250
    Anthony
    San Gabriel Ca
    Just saying, haha remember that PM you sent me you were like "F%$# You i think they are leaking now" or something haha
  14. Sep 14, 2011 at 10:48 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Oh yeah, I do remember that now.
    No they aren't leaking (yet) but they have softened up a little bit. Probably because of all the weight I've hung onto the front end. :eek:
  15. Sep 14, 2011 at 12:37 PM
    tacoma04
    tacoma04 Laissez les bons temps rouler
    Bruce
    Northern Louisiana
    2017 TRD OR DCSB BBP
    I have an 04 double cab, stock suspension. I measured the front from the floor to doors just behind the front fender flare. The rear measurement is done right before the rear door starts to curve up, so not as accurate. Anyway. 265x70R16 tires.
    Front driver's side 19 5/8"
    Front passenger's side 19 5/8"
    Rear drivers' side 20 1/2"
    Rear passenger's side 20 5/8"
  16. Sep 14, 2011 at 7:02 PM
    Anthony250
    Anthony
    San Gabriel Ca
    Thanks , I'm at 24 inches lol , so I guess 4 inches give or take
