Stock hub to fender measurement?
Discussion in 'Suspension' started by nvdeserted, Mar 28, 2010.
  1. Mar 28, 2010 at 12:36 AM
    nvdeserted
    nvdeserted [OP] Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Howdy, I finally got the new SAW c/o's settle in and then readjusted the front height to be even with the rear and level out the taco-lean.....
    I got it to within 1/10" all around with a full tank and me not in it.
    BUT I never made measurements beforehand so I'm not really sure exactly how much I lifted it :confused:
    If anyone has a stock 05+ TRD OR could you measure from the center of the wheel hub straight up to the bottom of the fender on the front only?
    Thanks!
    (I did search around a bit but the numbers were inconsistant)
  2. Mar 28, 2010 at 12:48 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    1/10 " ? , what kind a tape measure you using ? Only place I see tenths is on a rafter square .
    I have a stock front end on my 09 TRD sport 4x4 , would that measurement help ?
    OZ
  3. Mar 28, 2010 at 1:04 AM
    OZ-T
    Peter North
    British Columbia
    nv ,
    got out the flashlight , my truck measures 20 3/8" , centre of wheel hub to bottom of fender ,
    hope that helps ,
    OZ
  4. Mar 28, 2010 at 1:30 AM
    nvdeserted
    Reno, NV
    Ha! it was a cunthair less than an 1/8 so I estimated to a tenth. I spent a good 2hrs getting it perfect... i'm sure it will be .5" off tomorrow after more driving. As long as I had it almost perfect once I know it can't get any better and I'll stop looking at my truck from 5 different angles everytime I get in/out of it.
    And thanks for the second post, exactly what I needed. No flashlight for me, I'll compare in the morning.
    Thank you!
    gracianoh likes this.
  5. Mar 28, 2010 at 1:32 AM
    OZ-T
    Peter North
    British Columbia
    Cunthair , now that IS a legit measuring term for the professional builder !
    OZ
