Stock Intake Air Filter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, Aug 9, 2011.
  1. Aug 9, 2011 at 11:19 AM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    How often do you guy change it on your 4 cylinder trucks?
    What other maintenance you guys suggest I do? I have about 60k and only have done the oil changes every 4500. I know I gotta flush and replace the tranny fluid soon.
  2. Aug 9, 2011 at 3:22 PM
    pinktaco808
    nobody?
  3. Aug 9, 2011 at 3:35 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    I clean my K&N filter every 5k miles (every oil change)
  4. Aug 9, 2011 at 3:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I check my OEM filter every oil change, and replace when needed.
  5. Aug 9, 2011 at 3:43 PM
    JTacoma
    JTacoma Well-Known Member
    Washington
    1995.5 2.7 4X4 5 speed
    Icon Stage 2 Coilovers, Camburg UCAs, 33x12.50x15 Dick Cepek Trail Country EXP on American Racing AR201 15x10 wheels, differential drop, carrier bearing drop, BPV bracket, Leer canopy with Rhino Racks
    I used to change air filter every oil change, now I have K&N.
  6. Aug 9, 2011 at 3:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sorry to hear....
  7. Aug 11, 2011 at 10:42 AM
    pinktaco808
    so change every oil change?
  8. Aug 11, 2011 at 10:44 AM
    Joehs
    Joehs Well-Known Member
    Joey
    AL
    I clean out my AFE filter every 15,000 or so.
    With the stock filter, I'd just change it when I could see it was starting to get dirty? Seems like once or twice a year was more than enough.
  9. Aug 11, 2011 at 10:53 AM
    pinktaco808
    That much? Does it make that much of a difference?
  10. Aug 11, 2011 at 4:36 PM
    JTacoma
    Washington
    Went from 17 mpg to 22 mpg and I have a noticable hp gain.
    You would be fine if you put the right amount of oil on the filter instead of dipping it in a 5 gallon bucket of oil.
  11. Aug 11, 2011 at 4:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    An Air filter isnt going to give a significant gain in HP. The difference between an OEM filter, and NO filter in the air box is about 2 hp.
  12. Aug 11, 2011 at 5:19 PM
    JTacoma
    Washington
    Enough of a difference to not have to shift on hills. No lugging on hills in 5th where I used to have to shift to 4th. I know 5th is just overdrive but it works without problems up long hills. I also did the deck plate mod a while ago and just recently switched from stock filter to k&n but there was still a noticable difference in mpg and hp since the switch.
  13. Aug 11, 2011 at 5:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The gain was from the deck plate mod.
  14. Aug 11, 2011 at 6:10 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
  15. Aug 11, 2011 at 6:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep....a 30% gain from an air filter.......DONT think so.
  16. Aug 11, 2011 at 6:18 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    were can i get one of these....
