Stock inverter troubleshoot
Discussion in 'Technical Chat' started by Erik, Sep 26, 2011.
  1. Sep 26, 2011 at 10:07 AM
    Erik
    Erik [OP] That smells like pure gasoline
    Erik
    Nashua, NH
    10'TRD off-road
    Shrockworks bumper+ IFS skid, 4xInnovations rock sliders, Toytec Bilstein/Eibach 5100 @ 2.5", 3" All-pro leaf pack w/Bilstein 5100, PIAA 510SMR, PIAA 1500, Python LC3 2-way Auto-start, Fog lights on w/Parking lights, ATRAC Hack, Diff breather mod
    My AC outlet in the bed is not working. I checked all the fuses and they are good. The switch will light up for 100w/400w, but I get nothing when I plug something in. I pulled apart the center console and tested the wiring harnesses with my voltmeter and found it wasn't getting power there. How do I get it to work again?
    I will eventually get a better inverter, but can't swing it right now so I want this one to work.
  2. Sep 26, 2011 at 10:08 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Check the fuse?
  3. Sep 27, 2011 at 9:12 AM
    Erik
    Erik
    Nashua, NH
    10'TRD off-road
    Yes
  4. Sep 27, 2011 at 9:30 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Sorry, I must have skipped right over that.
    It could be the switch or the socket relay.
  5. Sep 28, 2011 at 4:19 AM
    Erik
    Erik
    Nashua, NH
    10'TRD off-road
    Wheres the socket? The wire harness thing that plugs into the inverter? Or are you talking about the outlet at the tailgate? I tested the outlet deff had no power. I also tested the wire harness thing going into the inverter and it had no power as well.
    Is there a relay involved in the inverter?
    That would be great if its the switch coz that shouldn't be that expensive. I will test it next chance I get.
  6. Sep 28, 2011 at 5:08 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    My post was supposed to say "relay" not "really". Sorry for the confusion.
    The relay sits in a compartment by itself on the outside of the main fuse box under the hood (driverside). The switch activates the coil of the relay which then sends the power to the inverter.
    If you pull the relay and meter the 1 & 2 terminals in the box after you turn the switch on, you will know of the switch circuit is working if you show 12V or higher voltage.
    The relay can be tested by supplying battery voltage to 1 & 2 posts on the relay. You can then check for continuity on posts 3 & 5 of the relay. You should see a very low resistance. Make sure the meter is set to the OHM setting.
    To check the circuit from the relay back to the inverter, you will will need to jump the the 3 & 5 terminals in the relay socket (reference page 4) Exercise extreme caution as there is 100A potential here.
    This is the electrical schematic for the inverter system. This is for the 05/06 model, but your should be the same.
    http://ncttora.com/fsm/05+/data/ileaf/06toyewd/06toypdf/ewd/2006/tacoma/h/em01d38.pdf
  7. Sep 28, 2011 at 5:33 AM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    Or just switch another relay in its place and if it works thats your problem (if you don't have a meter)
  8. Sep 28, 2011 at 10:19 AM
    Erik
    Erik
    Nashua, NH
    10'TRD off-road
    Awesome info! Thanks a ton. Especially for the links. I have the color circuit diagrams, but I have been looking for the pages that tell you where everything is located in the vehicle.
    I post how it turns out.
  9. Sep 29, 2011 at 4:59 AM
    Erik
    Erik
    Nashua, NH
    10'TRD off-road
    The relay works fine. The switch works. I must have somehow blown the inverter then.
  10. Sep 29, 2011 at 5:03 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I thought you weren't getting power to the inverter though?
  11. Oct 11, 2011 at 1:02 PM
    CalgaryRider
    CalgaryRider Well-Known Member
    Shayne
    Cranbrook, BC
    09 Access Cab SR5
    2009 Tacoma SR5 Too many to list, but its a SR5 with a TRD Sport Heart
    Do you have a picture of this compartment by chance? also does this relate to the fuse or relay 2D on page 24? http://ncttora.com/fsm/05+/data/ileaf/06toyewd/06toypdf/ewd/2006/tacoma/f/em01d0up.pdf
    The reason I'm asking is cause I put in the inverter and all the wiring from a TRD Sport into my SR5 and I get the switch on the dash to light up but will not say lit.
  12. Oct 12, 2011 at 6:40 AM
    CalgaryRider
    Shayne
    Cranbrook, BC
    09 Access Cab SR5
    Perfect, Thanks!
    I will look for that off the other wiring harness or in my truck.
    I would love to have this mod working before Halloween so I can have a little fun :D
