stock jbl
Discussion in 'Audio & Video' started by Siafu, Jun 25, 2008.
  1. Jun 25, 2008 at 6:19 PM
    Siafu
    Siafu [OP] Eat My Dirt
    Redlands!
    V6 Camry XLE
    Limo tint on Windows, Removed all emblems, Powdercoated Rims Black
    hey does the stock jbl system have the feature when you drive faster the music gets louder?
  2. Jul 1, 2008 at 10:56 AM
    Max
    Max Active Member
    07 Dbl Cab PreRunner
    yes.
  3. Jul 1, 2008 at 1:25 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Is there a way to set that? Because mine dosen't get louder when I speed up.
  4. Jul 1, 2008 at 1:53 PM
    Siafu
    Redlands!
    V6 Camry XLE
    yeah i think its called asl right where do you set it?
  5. Mar 20, 2009 at 5:55 AM
    Scooter
    Scooter Canadian Member
    Manitoba, Canada
    08 Double Cab TRD Sport Short Box
    Pop n Lock Power Tailgate Lock, Bak Flip Tonneau Cover, Factory DLR installed, Defrost with A/C Off, EZ Down Tailgate Damper, Code Alarm Security System with Remote Starter, Rear Spring TSB, Ming rust proofing & paint treatment, 3M fabric protector, Cargo Mat, Scanguage II, DYI Illuminated 4X4 Switch, Versa-Gate box extender & cargo divider, Toyota Roof Rails, Grom USB Audio adapter with bluetooth, LED Bed lights, OEM Backup Camera with LCD Display Mirror
    I have the stock JBL too. I just read through the audio section of the owner's manual and found no mention on ASL. How do you activate and set it?
  6. Mar 20, 2009 at 7:20 AM
    BlueNorthToyo
    BlueNorthToyo Well-Known Member
    07 DBL Cab, TRD, SR5 & Tow Package, 3" Lift
    3" Revtek lift, Access Laredo Tonneau Cover (awaiting delivery), Debagged Tailgate, Pop and Lock Tail Gate Lock (awaiting delivery), Grom I-pod hardwire, Chrome Side Step Bars, Hood Deflector, Window Vents, 15" Stubby Antenna, GE NIghthawk Headlights, Fog Light Mod, Hose Clamp Tailgat
    This is probably a stupid question but how do you tell the JBL form the non JBL. Mine came with the 6 CD changer, but I replaced in a while ago and don't really remember seeing JBL written on it??
  7. Mar 20, 2009 at 7:27 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    JBl will have the JBL logo on the head unit and on the door grills, at least on my '08
    and I think the ASL might only be on the '09's as a new feature, but I am not sure
  8. Mar 20, 2009 at 3:23 PM
    Msgtwhite
    Msgtwhite Member
    North Carolina
    13 Tacoma TRD Sport
    I believe only the 09 models have the ASL feature.
  9. Mar 20, 2009 at 6:18 PM
    BlueNorthToyo
    Thanks...pretty obvious now that I see it.
  10. Mar 20, 2009 at 7:56 PM
    lasllc
    lasllc Wait. . what’s wrong here
    Southwest RedRocks
    13 SuperWhite DCSB Sport TRD
    SnugTop Super Sport, BedRug mat, Redline Tuning hood lifts, LED interior lights, 3D carpet protectors.
    ASL -
    Push the right side knob - cycle thru the bas trebel etc until you get to ASL.
    Set it to Off, low med high.
    I have found that unless it is set to high it is sort of unnoticable.
    It also depends on the frequency range of the audio: voice is not as noticeable as jazz, classical not as noticeable as head-banger or that other stuff that you are forced to listen to at stop signs emmanating from a vehical six cars back.
