Stock leaf springs interchangable between XtraCab and Double cab?
Discussion in '1st Gen. Tacomas (1995-2004)' started by defleppardsg, May 1, 2012.
  1. May 1, 2012 at 7:43 AM
    defleppardsg
    defleppardsg [OP] Well-Known Member
    chris
    texas
    2.7L SR5 4x4
    OME 880's, Wheeler's Offroad 5-Leaf pack. Bilstein 5100's, 1" Daystar shackles, Deck Plate Mod.
    Will the OEM leaf springs from an Extra Cab fit on a Double Cab? Both trucks in the 01-04 generation. Dealer says there's different part numbers for the different leaves/trucks. But from all the stuff I've read on here, I've never heard this, so I wanted to check again.
  2. May 1, 2012 at 1:02 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    they might be different spring rates possibly due to the DC having more weight..could explain the differnt part numbers.
    but as far as i know, they are the same length.
  3. May 1, 2012 at 1:45 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Thats what I figure. Aftermarket are all the same so the length must be the same, just possibly rates or load capacity differences in OEM.
