Stock Length Lower Control Arms Questions
Discussion in 'Suspension' started by awwbugman, Mar 13, 2020.
  1. Mar 13, 2020 at 10:55 AM
    awwbugman
    awwbugman [OP] Well-Known Member
    Kings/Deavers/SPCs 35x10.5 Kendas, LRA FuelTank, WARN Zeon10s SDHQ mount, Switch Pro, LightForce rock lights, reverse light & Lightbar, Baja Design Squadron Pro fogs, CaliRaised Sliders, RLD Canopy, Odyssey group 31, Dometic CFX3-55IM
    I was considering going the route of aftermarket stock length lower control arms and had some questions. I was specifically leaning towards Dirt King, as my understanding is their LCA's will not reduce turning radius and do not require wheel spacers. I was hoping to ping some subject matter experts here to get a second opinion on potential cons of this route. What I understand to be the pros and cons are below, please let me know if I'm missing anything. For reference I have a 3rd gen TRD OR w/ King 2.5 EXT and adjusters, SPC UCA's and Deaver leaf pack on 33" tall skinnys (255/85/16). Solid input is appreciated (even the, that is dumb for this reason).
    Pros:
    -Increased durability
    -Increased clearance
    -Increased articulation (this one I'm unsure of, they mention it in a youtube video, however I have yet to see that quantified)
    -Replaceable skid plate
    Cons:
    -Cost
    -Weight? (I'm guessing they are heavier than stock, not sure)
  2. Mar 13, 2020 at 11:02 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    The only ones that tend to get reduced turning radius that I am aware of are the race standard lowers TC makes. They also have the expedition lowers now that do not reduce the turning radius. anyone that has a thinner part that sicks out should be fine.
    Also almost all will not need a spacer unless you are running the bypass shock. The spacer is to ensure you clear the shock not the LCA.
    If you plan to run a bypass you will prob still need a spacer or high offset wheels. I am running 3.5BS wheels so I do not have to run spacers but still had some shock rubbing but with some better hoop placement should good.
    The 4 options out there you will see the most of are:
    LSK
    Dirt King
    Camburg
    Total Chaos
    awwbugman[OP] likes this.
  3. Mar 13, 2020 at 11:11 AM
    nudavinci64
    Robert
    Also just to note I have the Standard Race TC Lowers. There is some reduced radius but you get used to it. Its the same limited radius the +2LT kit has as well.
  4. Mar 16, 2020 at 11:27 AM
    awwbugman
    Good input so far. Bump for more visibility.
