stock locker delay!?!!
Discussion in 'Off-Roading & Trails' started by 04asphalt, Jan 26, 2008.
  1. Jan 26, 2008 at 9:00 AM
    04asphalt
    04asphalt [OP] Well-Known Member
    PreRunner
    how long does your locker take to engage/disengage? mine seems to take several minutes sometimes:eek:
  2. Jan 26, 2008 at 9:04 AM
    rpoint16
    rpoint16 Well-Known Member
    Tempe, AZ
    2022 TRD Off-Road, Super White.
    Bone Stock
    Have not used it yet.
    I would think it should engage immediately...
  3. Jan 26, 2008 at 9:43 AM
    04asphalt
    PreRunner
    here we go again with the "toyota build-a-truck":mad:
    my wife is getting a new car and it won't be a toyota:(
    I grew up with toyota, tercel/celica/camery, and along with all the toyota cars my brother has had we never had all the defects!:eek: he switched to honda a few years back, I guess big brothers know.........
  4. Jan 26, 2008 at 10:44 AM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    i have to reverce and then go forward to get mine to come on you only can use it in 4lo
  5. Jan 26, 2008 at 11:30 AM
    ERdept
    ERdept Well-Known Member
    I push my button and hear a click from the rear. Push it again and hear it click.
    So, it takes as fast as it takes to push a button for me to turn it on.
  6. Jan 26, 2008 at 11:40 AM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    What does the manual say ? Are you under power when this is happening ? I know when I disengage the 4wd at highway speed I must de-accelerate before it disengages. maybe the same ?
  7. Jan 26, 2008 at 12:28 PM
    04asphalt
    PreRunner
    remember it's a prerunner 2wd
    sitting still I press the locker switch and it begins blinking, sometimes several minutes (3-7) go by until it locks and the light goes solid.
    just changed the oil and there was pressure in the unit!! unscrewed the filler bolt and poo, a bit of air pressure came out. I drove for about 15 minutes so it would get warm first.
    also on the drain plug there was a good amount of grim built up on the magnet, not metal flakes but like anti-seize in the unit!?
  8. Mar 2, 2008 at 9:50 PM
    evile
    evile Well-Known Member
    Orlando, Fl
    2006 DoubleCab TRD OffRoad PreRunner
    Bug shield vent visors Westin Chrome bull bar K&N Airfilter Pioneer CD/MP3/Ipod/DVD head unit KC Daylighters, LED map and dome lights, secondary airfilter removed. Black tube steps, 110v outlet in cab
    AT A STOP press the button the abs light will blink move the truck forward and it will engage. to disengage press teh button again and it will disengage some times you might have to turn the truck a little and will turn off
  9. Mar 5, 2008 at 6:49 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    yeah, after you hit the button you have to move the truck to engage the locker. sometimes forward and backwards and if that doesn't work then try moving with the wheel slightly turned. this is just how lockers work
  10. Mar 6, 2008 at 7:17 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I have a PreRunner as well. I have have created a handy dandy little phrase that tells you how to get it on.
    Stop.
    Lock.
    And roll.
  11. Mar 6, 2008 at 7:20 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sometimes it actually helps with the prerunner(auto) to put the truck into neutral, and you may still have to go reverse/forward to make it lock. it sometimes will get into a bit of a bind, but its usually not too bad.
  12. Mar 11, 2008 at 1:21 AM
    ERdept
    I have only used Neutral to engage it. Never park. Always clicked on and off a second after the button is pushed.
