Stock looking head unit?
Discussion in 'Audio & Video' started by 03f5sp, May 30, 2012.
  1. May 30, 2012 at 2:50 PM
    03f5sp
    03f5sp [OP] Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    I need a head unit with a aux out for a sub, but I don't like the look of most aftermarket head units. They just look out of place. Does anyone make a nice head unit that looks stock-ish with sub outputs?
  2. May 30, 2012 at 3:00 PM
    paul064
    paul064 Well-Known Member
    NE FL
    2005 4runner SR5 4WD
    Go to the audio/video section. There are alot of threads there about running RCAs from a rear speaker wire, eliminating the need to swap the head unit. I have considered a swap, but the factory h/u has more options than I've ever had, even more than some old aftermarket ones.
  3. May 30, 2012 at 3:54 PM
    03f5sp
    Bill
    Wisconsin
    The other issue is I only have a single disc changer. Would swapping it out for the stock JBL unit do the trick? Does it have an output for subs?
  4. Nov 15, 2012 at 10:32 PM
    Tommy27
    Tommy27 Well-Known Member
    Tommy
    Boise,ID
    White 09 AC 4x4 2.7 5spd SR5
    Leer shell, Bed mat, Grill Guard
    More info!
  5. Nov 16, 2012 at 8:09 PM
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    Back from the dead... lol. To the OP and Tommy I don't think you'll find a 'stock' looking head unit in the aftermarket. Try looking at the double DIN units to see if something peaks your interest.
    Without knowing any specifics such as goals or budget it's hard to try and help plan out a system. Why not invest in an amp with speaker level inputs like this one: http://www.sonicelectronix.com/item_22733_Kenwood-KAC-7205.html
    It will allow you to have a sub without the need for RCA outputs. Yes that amp is a little overkill for only having stock deck/speakers. You'll be able to use it for something else later on when you decide to upgrade instead of sitting on a shelf.
  6. Nov 17, 2012 at 3:01 PM
    03f5sp
    Bill
    Wisconsin
    I ended up with a Clarion. I thought it would look ricey but it actually looks pretty good.
