Stock lug nuts on spare tire?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by O'SHIELDS, Mar 19, 2016.
  1. Mar 19, 2016 at 9:39 AM
    O'SHIELDS
    O'SHIELDS [OP] Member
    jared
    Tallahassee, Fl
    97 tacoma 2.7 4x4
    3in suspension 2in body
    I got a flat last night and I'm changing the tire for the spare tire right now. This might be a dumb question but i was just wondering if its ok to use the stock lug nuts on the spare tire? looks kind of weird because once its torqued down there will be almost 1/2" gap between the nuts and the rim. Its a 2013 off road
  2. Mar 19, 2016 at 9:42 AM
    O'SHIELDS
    jared
    Tallahassee, Fl
    97 tacoma 2.7 4x4
  3. Mar 19, 2016 at 9:45 AM
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    There is no problem with that ;) the tip of the stock nut is made to fit on the spare. I rolled mine a few weeks and had no issue
  4. Mar 19, 2016 at 11:22 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes you are fine as long as they are tight. The stock nuts are multiuse type nuts.
    AR15xAR10 likes this.
  5. Mar 19, 2016 at 11:25 AM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    They aren't meant to be used for an extended length of time, but the will work fine for a day or two until you can swap back on your regular wheel and tire
