Stock OEM Oil Drain gasket
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pster, Feb 15, 2009.
  1. Feb 15, 2009 at 9:40 AM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Changing my Mobil 1 Synthetic and filter today to install my Fumoto oil drain valve. The reason I had never changed the original oil drain plug gasket was because it was stuck to the oil pan. Got it off with a putty knife. It is aluminum. Or more correctly aluminium. I have not decided yet but likely to replace it with a fiber composite, nylon or copper.....leaning toward copper as I never want to have to replace it for the remaining life of the truck.
  2. Feb 15, 2009 at 10:38 AM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    i don't know if you saw it on there but there is a small layer of fiber or whatever on both sides.
    i bought a pack of 10 from a yota parts site and just change it everytime time.
  3. Feb 15, 2009 at 10:51 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Judd94, I inspected it carefully, it is 100% aluminum with - suprisingly - black paint on both sides.
  4. Feb 15, 2009 at 1:04 PM
    sliverworm
    sliverworm Well-Known Member
    Austin, Texas
    06 PreRunner TRD Offroad
    why would you change it? I dont understand, I have never changed that in any of my other vehicles..
  5. Feb 15, 2009 at 1:18 PM
    Joe B
    Joe B Well-Known Member
    The Fumoto gasket never needs to be changed.
  6. Feb 15, 2009 at 1:31 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    1999 tacoma, never changed the "washer". I was in the same boat. I was told by the stealership to change it every time, which I didn't(Ido my own oil changes) and I said what the hell, lets see what happens. No leaks. Aluminum washer, just search on here and see what everyone else thinks about it. It's been discussed before. If it doesn't leak and isn't broke, don't fix it.
  7. Feb 15, 2009 at 1:37 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Unless a washer is a crushable type, no need to change it with each oil change. I just installed and found the copper seemed to give a very good seal with compressing, so I used it.
  8. Feb 15, 2009 at 1:48 PM
    Snyperx
    Snyperx Seniore Marcos
    Never change your oil drain gasket? Seriously? I change it every time. In fact, the one time I did not change it I had a slow drip. Also, I know when I had the dealer do my first couple of changes they also replaced the gasket.
  9. Feb 15, 2009 at 1:57 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    25,000 miles and same gasket, not a drop.
  10. Feb 15, 2009 at 2:28 PM
    Monkeysuncle
    Kevin
    Florida
    I have been in the same boat, a "crushable washer" was common on my previous 2 Volkswagens, one air cooled one not. My Tacoma has never had an oil leak from the drain plug. Cam seals...yes, drain plug no. So buy a new washer for the drain plug if it makes you sleep better at night, but in my 6 years of owning my 3.4 V6 I was concerned but never replaced the washer, and never had a leak out of the deain plug. JUst my 2 cents:) Kevin
  11. Feb 15, 2009 at 2:28 PM
    HighPlains
    HighPlains Well-Known Member
    So did you ever find that metric pipe fitting you were looking for?
  12. Feb 15, 2009 at 2:37 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Good question! In fact, Fumoto now sells an oil drain valve with the exact right angle elbow I was looking for, except it's only offered on a valve that does not fit the Tacoma. Maybe soon they will expand it to other valve models. I'll see if I can find a pic of it.....
  13. Feb 15, 2009 at 2:39 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Here it is. It is called an "L type", as opposed to the "N type" which has the nipple dropping straight down.
  14. Feb 15, 2009 at 5:46 PM
    moserjjx
    moserjjx Tacoma Newbie
    Eau Claire, WI
    08 DC TRD 4x4
    Weathertech liners, bed mat, rear spring TSB, extra 12V outlets in center console, seat belt chime off
    i've changed oil on hundreds of cars and probably changed 3 drain plug gaskets. i wouldn't change it, i have no plans to change the gasket on my truck unless it leaks. properly tightened, the orig gasket will last quite awhile
  15. Feb 16, 2009 at 6:35 AM
    Jeff
    Jeff Well-Known Member
    Hopkinton,MA
    Nice 6spd,V6, very solid truck
    None currently, but I would like a better sounding exhaust and perhaps a cold air pack and some color coded step bars
    Same as "monkeys uncle" , I was told to change it every time bought an extra just in case, used the old one and it never leaks and I do not over tighten it, just the usual snug and 1/4 turn.....
    Jeff , 06,V6, SR5, 4x4, Radiant Red
  16. Feb 16, 2009 at 8:02 AM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    I used the gasket that came with the plain Fumoto valve, no N or L, with no problems. It is farther out of harms way by being slightly shorter and it drains right in the drain pan with no splatter or mess. Save a few bucks and just get the regular one. Model F-103
    http://www.fumotousa.com/
  17. Feb 16, 2009 at 8:10 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    ^^ Hi 4x4x4TRD how's little lucy the doxie? Been missing her pictures! ^^
    OT, one filter I bought from the stealer had the fiber typewasher in the box, the 10 I bought online came without so guess I need to pick some up.
  18. Feb 16, 2009 at 8:13 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I for one am tired of the oil flow splashing out of my drain pan so I got the one with the nipple......with 5/8" hose attached and then the 5/16" hose attached to the oil filter drain I don't plan to touch the stuff anymore. I put a screw cap over the nipple as well as the valve body to keep water and dirt/debris out of it.
  19. Feb 16, 2009 at 8:14 AM
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
    I just left mine stuck to the pan...hahah... never had a leak.
  20. Feb 16, 2009 at 8:56 AM
    4x4x4trd
    North Texas
    The small stream out of my Fumoto doesn't splatter and a reused 6oz cup under the filter trap while I pull and replace the rubber plug and I'm done in about 5 min. without a drop of oil on the hands. To each their own. ;)
