Stock Off Road Wheel Weight
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chris(NJ), Aug 15, 2011.
  1. Aug 15, 2011 at 5:27 AM
    Chris(NJ)
    Chris(NJ) [OP] Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I wanted to post this information mostly for search purposes b/c the only other weight posted (that I found) on the site did not come even close to what I had. So dont mind the extra wording here. I'm trying to cover everything someone would use to search for the info.
    So the stock tacoma 4x4 oem off road OR wheel rim weighs 22.2-22.4 pounds. It fluctuated between these two numbers on my scale. Pic for proof :cool:
    guidoStow, cbstewart, Musubi3 and 5 others like this.
  2. Aug 15, 2011 at 2:41 PM
    SATXguy
    SATXguy Well-Known Member
    San Antonio
    2017 4x4 TRD Off Road
    Mobtown Front Recovery bar Relentless Fab Bed bars (3) Quickfist 2 pair Husky Floor Liners Cali Raised bed channer stiffeners Cali Raised low profile ditch light bracket 27 watt ditch light pods w/ side projection OEM Ditch Light switch Roam Adventure Co. Roof top tent Roof top tent annex Costway 54 Quart Portable Refrigerator/Freezer Compact Smittybilt 2789-99 Transit Bag NOCO GC019 12-Foot 12V Adapter Plug Socket Extension Cable Scoshe Magic Mount for Iphone plus Hypertech Speedometer calibrator BFG KO2 AT 265/75/16 JDMCar Center Console Organizer TRD pro Grill TRD PRO Grille Vinyl Decal Gloss Super White X-Bull Recovery Traction tracks 3rd gen CamPark ACT 74 Action Camera DC cargo 2" Diameter Black Steel V-Ring BoltOn Trailer Cargo Tie-Down CLC 1173 32 Pocket Socket Tool Roll Pouch Viair 00088 88P Portable Air Compressor Toyota Accessories PT580-35050-SB Bed Mat for Select Tacoma Models Rhino USA shackle hitch receiver Toyota Accessories PT580-35050-SB Bed Mat for Select Tacoma Models Smittybilt 3x30 recovery strap 30,000 lb capacity Smittybilt 3/4" D-Ring Shackle (Black) 4.75 ton rating 12V 140 Amp Dual Battery Isolator by KeyLine Chargers - Voltage Sensitive Relay Gen 3 Tacoma Auxiliary Battery Tray
    Good Info! Thanks, because I lost about 2 mpg when I changed tires from the stock BFG rugged trail to the BFG AT because of the additional weight (200lbs). So when I upgrade rims I can compare the differences.
  3. Aug 15, 2011 at 2:48 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    good info. i will also use when i get new wheels and tires.
  4. Aug 15, 2011 at 5:18 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Glad it helps! :)
  5. Aug 24, 2011 at 8:02 PM
    WhiskeyDeltaTango
    WhiskeyDeltaTango Resident Redneck
    Will
    Braselton, Georgia
    Dirty Black Taco
    ARB Bull Bar, ProComp 9" lights, Dual Hella aux backup lights, WARN VR10000, OME 886x, Dakar Leafs, UWS Low Profile Toolbox, Kicker CVT10, Kicker 750.1
    Finally! i've been looking for this!
    seeing as how our wheels are already pretty light. anybody found anything lighter besides those konig countersteers?
  6. Aug 25, 2011 at 5:15 AM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Kolter45 likes this.
  7. Aug 25, 2011 at 5:17 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Anyone know how much 1st gen trd wheels weigh?
  8. Aug 25, 2011 at 5:19 AM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Whiskey; The MT classic IIs were fluctuating between 19.4 and 19.6 w/o center caps (which were probably only a few more ounces).
  9. Aug 25, 2011 at 8:17 PM
    WhiskeyDeltaTango
    Will
    Braselton, Georgia
    Dirty Black Taco
    sweet, I was actually looking at getting those. Those MT were listed at like 24 pounds our something
    EDIT: Any issues with the MT fitment? truck looks awesome with them btw
  10. Aug 26, 2011 at 6:07 AM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    THanks man. No fitment issues at all. They're perfect. The only thing was an issue was w/ the wheel weights when applied to the inner section of the barrel for balancing. They were hitting the caliper, so the shop had to use the hammer on weights on the inside to avoid that. Stick on weights on the outside portion were fine though.
    And the only thing I can think of w/ the published weight vs what I weighed them, is the rim size they used for advertising. If they used a different width/specs than what I have, that may have made up the difference.
  11. Apr 3, 2013 at 9:30 PM
    Phenom3030
    Phenom3030 Well-Known Member
    Jon
    Colorado Springs, CO
    2021 Lunar Rock TRD Pro
    OEM+
    Thanks for posting, very helpful piece of info!
  12. Apr 8, 2013 at 10:02 AM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    No prob! Can never have too much information! :)
  13. Apr 8, 2013 at 1:19 PM
    mytaco77
    mytaco77 Well-Known Member
    So Cal
    08 dbsb 4x4 TRD
    I was looking for this info as well. Thanks. I read on a different post that they were 25lbs. They must of rounded up. I'm definitely looking for something lighter than my OEM rims.
  14. Apr 12, 2013 at 8:35 AM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    :thumbsup:
  15. Nov 20, 2019 at 5:43 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    Same!
    Chris(NJ)[OP] likes this.
  16. Nov 21, 2019 at 5:01 AM
    badger
    badger Well-Known Member
    07 SR5
    This is an old thread, but correct. There is a good thread in the wheel forum that has reliable weights. Just as a general comment, getting weight numbers on anything online is extremely sketchy. People post when they don't know (gotta love that). People google it and then post the shipping weight which includes all the packaging, and then that number is rounded up. 90% of online posted weights are bullshit.
    This particular wheel does weigh 22.2 pounds. It is one of the best wheels you can run when considering strength/weight. The weights of Toyota wheels have been creeping up for years until they finally reached 26.2 lbs! Toyota's newest 2020 TRD Pro wheel (7.0 x 16) resets the scale at 21.4 lbs. Toyota blows their horn that they have reduced the wheel weight by 4.8 pounds!!! Wahoo!!! Truth is, they have reduced the weight 0.8 pounds from a design they created 15 years ago! You've always got to have your bullshit sifter fully engaged!!
    Bottom line is that the old tried and true Toyota wheel shown in this thread is a huge bargain. You can easily pick them up for $200 a set or less. I think I have 9 or 10 of them, and I'm not selling them. They are light and are very well designed for strength. I think the new Pro wheels are good too, they just come with a new wheel premium for price. They have just become available in the last couple of weeks.
    Now you are informed......
    Edir: The P/N for the new 16" 2020 TRD Pro wheel is PT946-35200-02. It may not be in every dealers system yet, but that is the number.
    TomHGZ and Chris(NJ)[OP] like this.
  17. Nov 21, 2019 at 8:36 AM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Yea, I tagged him in that thread and linked him to this post so that he can update his original post.
    badger[QUOTED] likes this.
