Stock or OME springs on 5100
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chechare, Sep 30, 2019.
  1. Sep 30, 2019 at 7:28 AM
    chechare
    chechare [OP] Active Member
    cesar
    I’m about to pull the trigger on a set of 5100s. Just don’t know if I should buy ome 2885, 2887, or keep my stock Sport springs.
    i know OMEs do the lifting with the shock at 0, as opposed to the shock doing the lift on the stock spring.
    what’s the difference, comfort wise? I’m only looking for 1 1/2 - 2 inches. I’m not planning on adding bumper, winch or any heavy stuff. I don’t want my ride to end up bouncy or stiff. Streets around here qualify as off road.
    ozpall likes this.
  2. Sep 30, 2019 at 10:41 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I personally didn't feel a difference in mine and my neighbor who runs 888s and his second set in now sagging. They both ride the same and I'm on stock sport springs on the 4 the perch. Rides great and I think either way is fine. Don't listen to this bullshit that it will ride harsh. Mine rides a lot better than the stock sport struts gave me. There is a big misconception that you need to change the springs. I run a rear block, front diff drop, rear carrier drop, and stock UCA, added 265/70/17 Toyo open country at2 SL rated tires and the ride is grea, no shaking or vibrations, I also did the ecgs clamshell bushing. No issues at all.
  3. Sep 30, 2019 at 10:57 AM
    chechare
    cesar
    thats what i was hoping. Why did you do the diff and carrier drops and ecgs, are they needed? i think ill be installing Grabber ATX 265/75/17.
  4. Sep 30, 2019 at 11:11 AM
    VaToy
    Parts Unknown
    The shop kept everything in spec so there would be no vibrations. They thought it was best.
