Stock pullys vs after market
Discussion in 'Performance and Tuning' started by JOE619, Apr 23, 2013.
  1. Feb 12, 2015 at 1:44 PM
    BradyT88
    BradyT88 Well-Known Member
  2. Feb 12, 2015 at 5:28 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  3. Feb 12, 2015 at 6:11 PM
    anthonytacoma
    anthonytacoma Well-Known Member
    Torspd- sent you a pm
  4. Feb 12, 2015 at 8:59 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    ^^^^ Torspd is right... NST stopped making pullies for the 1GR years ago!
  5. Feb 12, 2015 at 9:03 PM
    Yota64
    Yota64 Professional Threadjacker
    Why don't automakers make pulley's light to begin with?
  6. Feb 13, 2015 at 6:40 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Cheapest design possibly that lasts the longest, which fits the budget for the vehicle. More expensive vehicle = more money for development and better parts.
  7. Feb 13, 2015 at 9:57 AM
    1tacoplease
    1tacoplease I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    PM sent.
  8. Feb 13, 2015 at 9:59 AM
    1tacoplease
    Temecula
    I emailed NST and they have 3 lightweight pullies for sale. Crank, alternator, and water pump. For all three the cost is $318. Hope that helps.
  9. Feb 14, 2015 at 7:50 AM
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    I was planning in getting that combination but I heard ALOT of people pay and NEVER get their pulleys OR money back. Please let me know if it works out for you. This was on my mod list years ago.
  10. Feb 14, 2015 at 8:18 AM
    StuckinOhio
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    Also on a side note when considering replacing the crankshaft pulley consider that there are other design criteria than just powering accessory drive belts.
    I could be wrong, but I thought I read that the stock crank pulley has a built in harmonic balancer. (this helps dissipate crankshaft vibrations). The NST does not have anything to reduce vibrations. Read this article if you're curious on understanding more about what I mean HERE
  11. Feb 16, 2015 at 11:47 PM
    1tacoplease
    Temecula
    Does anyone know if our stock 1gr crankshaft pulley has a harmonic balancer?
  12. Mar 14, 2015 at 6:10 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    What they call the crankshaft pulley sure looks like a harmonic balancer, but it doesn't seem to have any sort of keyway to control orientation so perhaps not. BTW the main advantage of after-market pulleys is not reduced weight. They offer increased power by limiting parasitic loss through the alternator, power steering pump, even the water pump. By making these pulleys larger, the shaft speed is lowered. I've done this on multiple drag cars with my son. There are side-effects. If you slow down something, it does less work. For the P/S pump, steering effort at low RPMs will be increased since the pump has less output. The alternator will produce less current at lower RPMs so the low voltage warning might flicker with lights and air-conditioning on. And of course, slowing down the water pump will reduce cooling at lower RPMs.
    Good idea for drag racing, not so good for a daily driver most of the time.
  13. Mar 14, 2015 at 6:40 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The crank pulley has a rubber insulator between the ribbed portion and the crank portion. it is not necessarily a harmonic balancer, but it does isolate harmonic vibrations. 1gr is internally balanced and does not need a harmonic balancer. however both the OEM and the NST pulleys do have a key way for timing configuration.
    if you want a harmonic balancer for the 1gr engine, then you need to purchase the one from ATI.
    http://www.atiracing.com/links/pr/Toyota-1GR-FE/
    talk to text for the win.
  14. Mar 15, 2015 at 9:36 AM
    RobertHyatt
    Robert
    Birmingham AL
    Personally I despise that rubber insert. At about 70K my older ranger started to have a "chirp". Thought it was an idler or the tensioner (hard to see down in there). Then became convinced it was the water pump which had just started to "weep" a few drops from the weep hole. Still not it. Turns out the belt drive pulley was walking off of the harmonic balancer because the rubber was giving up the ghost. So the belt was no longer running in an aligned path, the crankshaft pulley was sticking out about 1/2" causing the chirp with a misaligned belt. My son and I fixed many of these over the years. Seems like more fords than anything, but we also saw it on a Corvette (An incredible bitch to fix, by the way).
