Stock rear height
Discussion in '2nd Gen. Tacomas (2005-2015)' started by raycie, Mar 21, 2011.
  1. Mar 21, 2011 at 5:35 PM
    raycie
    raycie [OP] Well-Known Member
    Oahu, HI
    16 T4R Trail
    In need of $$$
    Anyone by chance know, or anyone with a fairly new long bed Tacoma care to measure...
    Looking for the stock height (unloaded bed) from the top of the leaf springs (non-tsb) (bottom of the bump stop) to the frame.
    I can't measure mine - 07, seen it's share of some heavy loads, 2"aal, snugtop shell.
    Have some timbrens in the mail, but curious what the measurement is stock.
    Thanks...
  2. Mar 21, 2011 at 7:04 PM
    jmayday23
    jmayday23 Well-Known Member
    Joel
    North Carolina
    '10 4WD TRD Sport DCLB
    Grillecraft, Hella 500 HIDs, weathertech mats, yellow fogs, OME 885's with shocks and AAL. Bridgestone Revos 285/70-17
    Not the measurement you're looking for, but today I measured my DCLB from the ground to the fender lined up with the center of the wheel and got 36" in the rear. My truck's a 2010 with just under 6000 miles, very little heavy loads ever in the bed.
    good luck!
  3. Mar 21, 2011 at 7:41 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Since no one has answered your question yet, I'll at least tell you that I had a hard tonneau on and two 60-lbs sandbags in the back when I installed my timbrens years ago (no AAL at that time). I was unable to slide the timbrens in until I removed the two sandbags. Then they cleared by maybe half an inch. So at stock heights without a tonneau (empty bed), I'm guessing you'll have an inch or less clearance.
  4. Mar 22, 2011 at 12:09 AM
    raycie
    Oahu, HI
    16 T4R Trail
    In need of $$$
    Really? The timbrens (longer one) comes in at 5". With my snugtop (200lbs or so) and my 2" aal, I have 7 inches from leafs to frame. Needed to have timbrens send wheelers a 2" spacer as I was sure the sag of the shell was at least 1"- 1.5". So basically what I was trying to find out was if a stock truck has 1.5" or 2" of gap leafs to frame.....
  5. Mar 22, 2011 at 7:31 AM
    05Moose
    Jim
    With my tonneau and the wheeler's 1.5" AAL, I didn't get a spacer. In fact, without the AAL, the timbrens (IMO) were too close to the frame in that it caused the ride to be a little more bouncy since they were getting used on every bump. The AAL added an extra 1-2 inches of space above the timbrens now (even with tonneau on) and I think that's how they should be. Now they're only used when hauling a heavy load.
  6. Mar 22, 2011 at 9:05 AM
    raycie
    Oahu, HI
    16 T4R Trail
    In need of $$$
    when I spoke to someone at timbrens they commented that with the weight of a snugtop, I should have the timbrens very close if not coming into contact already. Guess I will just need to have to install the 7" and see how she rides.. If it's crap, i'll request another 1/2" spacer and have them ride 24/7...
  7. Mar 22, 2011 at 2:31 PM
    rednecktaco
    rednecktaco Well-Known Member
    wv
    81 4x4 long bed, wk2
    taco, inchannel vent visors, sat radio, undercover bed cover, and little stuff. 81 has a few.
    best i have is a excab stock was driver 36 1/2 pass 36 1/4 from the ground up stock everything. after tsb springs driver 37 1/2 pass 37 3/4 all got
  8. Mar 25, 2011 at 2:03 PM
    raycie
    Oahu, HI
    16 T4R Trail
    In need of $$$
    Damn... Guess I have to take off to snugtop to get actual measurements. Just measured my height and came back with 38.5. That would make total sense as I have 2" aal in the rear, and have gone to 70's...
    BUT... That is my measurement with a snugtop on the bed...
    Just installed the timbrens today. Frame is just barely resting on them (as planned)..Because of the camper...
    200 or so lbs should drop at least 1" right???
