Stock Rear Shocks with 1" Blocks? Pics
Discussion in 'Suspension' started by Rhody76, Oct 25, 2012.
  1. Oct 25, 2012 at 4:29 PM
    Rhody76
    Rhody76 [OP] Well-Known Member
    Rhode Island
    2011 SR5 DCLB 4x4
    Rear leaf TSB, Bilstein 5100s set at 1.75",1" blocks, UWS low profile toolbox in black, husky liners, tint, LED interior and reverse lights, yellow fogs
    Hey Guys- Just had my mechanic buddy install 1" rear blocks on my 2011 DCLB. I already had the rear leaf TSB and front bilsteins set at 1.75" The truck is leveled out nicely and has roughly 2" of lift from stock. Ready for my new rims and tires.
    I am wondering if I need to change out the stock shocks? They are obviously extended a bit further now so I'm not sure if this is an issue or not. If so, what shock should I replace them with?
    Also what is the best fix for the taco lean?
    THanks!
  2. Oct 25, 2012 at 5:48 PM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    anyone?
  3. Oct 25, 2012 at 5:57 PM
    hanrock
    hanrock Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    i ended up putting on shock extenders until i decide which route im going to go as far as shocks i have 4 leaf as well and mine top out on harsh speed bumps ect my blocks are 1 1/4 the extenders are on the toytec site
  4. Oct 25, 2012 at 6:49 PM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    I am not familiar with shock extenders but sounds like a short term fix. No problems yet but I dont want to cause any damage
  5. Oct 25, 2012 at 8:03 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I've had my blocks on for 2yrs, other than feeling them top out on harsh bumps cause the rear of the truck is so light, I've had no damage yet. An yes I'll be changing them out for a new susp soon
  6. Oct 26, 2012 at 2:26 PM
    06sr5prerunner
    06sr5prerunner DILIGAF
    luis
    midland tx
    2006 sr5 prerunner
    bhlm paint wheels duplicolor plasti dip white grill. billies 5100. bf goodrich at 285's 75 16 black valence led corner lights expedition bed rack by anb fabrication spidertrax wheel spacers rotopax fuel tanks 4gal mounted on bed rack quickfist mounts for shovel. ddm hid kit 35watt 6000k hi/low beam
    i just got 1" blocks as well. havent installed yet though. did you use your stock u bolts or get longer ones. ?
  7. Oct 26, 2012 at 3:39 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    you need 1in longer bolts which should measure 8.5in, stock is 7.5in
  8. Oct 26, 2012 at 7:06 PM
    06sr5prerunner
    luis
    midland tx
    2006 sr5 prerunner
    even though i dont have tsb? i have read on here that some guys did not change them and some did. i guess i should check how much thread sticks out on them right now but prob should buy some.
