Stock Rim & Wheel Weight
Discussion in 'Wheels & Tires' started by m3dragon, Oct 22, 2007.
  1. Oct 22, 2007 at 8:37 AM
    m3dragon
    m3dragon [OP] Well-Known Member
    Sacramento
    What is the Weight of the stock 17 inch rim?
    And 16?
    With Tire and Wheel installed and at recommended tire pressure.
    Trying to keep the unsprung weight the same or less when I do the rim upgrade.
    Thanks
  2. Apr 29, 2008 at 2:28 PM
    Zach
    Zach Well-Known Member
    Phoenix, AZ
    08 DC Prerunner SR5
    Window tint...more to come
    Found this thread buried in the search. If anyone happens to have an answer, i would like to know as well. I have a prerunner SR5, would love to change the wheels but keep the tires (since they are new) and weight of the truck the same.
  3. Apr 29, 2008 at 3:28 PM
    m3dragon
    Sacramento
    Once my the tires are burned up I will change the rims and let you know.
  4. Sep 4, 2008 at 4:38 PM
    m3dragon
    Sacramento
    Bump for a unanswered thread
  5. Sep 4, 2008 at 4:56 PM
    m3dragon
    Sacramento
    That is not the rim weight. That is the rim / with tire weight. Do you have a tire installation machine in your garage? If so hook us up with the weights.
  6. Sep 4, 2008 at 5:22 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    Look up your tire on Tire Rack.:D They have/list the lbs.
  7. Sep 4, 2008 at 6:01 PM
    m3dragon
    Sacramento
    LOl funny guy. :p
    I know tirerack lists the weight of the rims I want to go with. ASA is the lightest rim there at 23lb. However what is the stock 17 rim weight? If it is like 20lb then it would not be a smart move to change the rims.
  8. Sep 4, 2008 at 11:08 PM
    cleanTRDmachine
    cleanTRDmachine watch the meat
    Kyle
    Q-Town, PA
    06 DC TRD
    tint gray camo seat covers debadged color matched grille surround off of 06 TRD sport grillecraft black mesh grille Hella 500's demudflapped Toyota rear leaf TSB (first edition) 265/75/16 BFG AT TA KO's Flowmaster Super 40 #952445 Maglite Mod AntennaX 13in antenna Painted Lower Valance Vision X H4 Xenon headlights Halo Solaris H10 foglights Velocity Offroad 2.5 leveling kit (removed) Spidertrax 1.25" wheel spacers Rocky Mounts Clutch SD bike mount 4ft combo lock cable for bed extender Stage I interior LED's Toytec 1.5" AALs Extang Trifold Signature Series Bed Cover Reese front mounted tow hook Icon Stage 1 Suspension
    total weight on the bathroom scale - tire weight = rim weight
    mallege likes this.
  9. Sep 5, 2008 at 8:08 AM
    m3dragon
    Sacramento
    No that is is tire weight + rim weight = total weight.
    Rim weight is one component of total weight. You can change the size of the tires to change the tire weight.
    I have called 2 dealers and both of them have no clue what the weight is. I even tried to convince one of them to take the one they had on display and remove the tire with no luck.
    Please don't post unless you have helpful information
  10. Sep 5, 2008 at 8:24 AM
    m3dragon
    Sacramento
    Finally found the stock 17 wheel weight. Took calling 4 dealers to get it.
    Stock 2005-2009 Toyota Tacoma 17 wheel weight is.
    28.9LB
    So the 18 inch 23LB ASA rims I was looking at are not only are lighter but can run a lower profile tire to gain performance.
    Truncali82 likes this.
  11. Sep 5, 2008 at 8:26 AM
    Zach
    Phoenix, AZ
    08 DC Prerunner SR5
    Thanks m3 appreciate the information and work tracking it down. Rep to you!
  12. Sep 5, 2008 at 12:20 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    plus 1 to you!! thanks so much for posting the answer.. ive been looking everywhere to find the weight of the rim as im considering changing wheels... 28.9 pounds is alot heavier that i thought they were going to be
  13. Sep 5, 2008 at 12:47 PM
    m3dragon
    Sacramento
    Ya they are pretty heavy. The lightest rims I can find for us is ASA. The 18 inch rim is only 23LB.
    So if you do more street driving then run a 18X8.5 with a 265X55 tire. This will give you more grip but not so much it hurts the MPG. Plus beign 55 it will save the rim but give you corner stability.
  14. Sep 5, 2008 at 1:35 PM
    m3dragon
    Sacramento
    Just for kicks found the wheel weights for the X-runner 18inch rimes
    Wheel weight is 31lbs - 32lbs (as advertised)
    Tire weight is 29lbs (as advertised)
    Wheel/Tire weight as weighed with 34lbs of tire pressure - 58.2lbs
  15. Sep 5, 2008 at 1:37 PM
    tacoskim
    Los Angeles, CA
    Stock
    i guess the tire/wheel ratio evens out compared to the sports 36 pound tire with 28 lb wheels
  16. May 9, 2016 at 7:56 AM
    R09ster
    R09ster Well-Known Member
    Josh
    OK
    06 SSM DCSB TRD Sport
    debadged, Bilstein 5100 all around (fronts at 1.75" sport coils), Skyjacker softride 1.5" AAL, Firestone Ride Right Airbags, 17X8.5 Method NVs, 285/70/r17 Falken Wildpeak AT3W, US Offroad hidden winch mount, grillcraft grill, Sypder Auto projector headlights, blackedout LED taillights, bed extender, bedrack w/CVT Mt Shasta tent,
    noted
