Stock Roof Rack Wind Deflector
Discussion in '2nd Gen. Tacomas (2005-2015)' started by inlinejohn, Apr 20, 2010.
  1. Apr 20, 2010 at 7:55 AM
    inlinejohn
    inlinejohn [OP] Well-Known Member
    Washington
    08 Tacoma TRD Sport SR5 4WD LB
    3" spacer/AAL lift, Toyo Open Country MT 265/70R17, Kenwood USB, Truxedo LowPro QT, Grillcraft w TOYOTA emblem...coming soon, Avid Offroading Sliders...coming soon.
    Anyone seen a mod on this theme? I'd like to make a wind deflector to attach to my stock roof rack.
  2. Apr 20, 2010 at 8:15 AM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    Why not just put the bars away? I'm not sure if it would look nice because of the low angle.
  3. Apr 20, 2010 at 8:41 AM
    rwcfrank
    rwcfrank Well-Known Member
    08 SR5 Prerunner
    That looks like an interesting mod. I would use a piece of black plastic ABS from TAP plastics. You can attch it permantly with plastic rivets but that would leave holes in the roof bracket. The mounting options are limited but it can be done. Subscribed to this thread...
  4. Apr 20, 2010 at 8:59 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    That'll look great.
    I'd like to see clear abs with lights behind :)
  5. Apr 20, 2010 at 9:02 AM
    inlinejohn
    Washington
    I'm being a little anal, but I like the look of the bars in cross position better, but the noise/drag is too much.
  6. Apr 20, 2010 at 9:05 AM
    inlinejohn
    Washington
    This is what I was thinkin, but wanted to see if it's been done already before I make an attempt. I need to look at the Yakima/Thule version and see if they seal up the front lower surface or just leave it open. If so, then it's pretty easy. Just fasten new deflector to front of roof rack sides. I would use self-taping screws with a little seal under washer.
  7. Apr 20, 2010 at 1:06 PM
    rwcfrank
    08 SR5 Prerunner
    Just be sure the leading edge doesnt touch the roof paint or the movement under speed will certainly wear through the paint.
  8. Apr 25, 2010 at 11:05 PM
    gtec913
    gtec913 Well-Known Member
    glenn
    cali
    hey bro i have a old picture of my 09 truck with the yakima fairings i had on custom brackets i made on my stock roof rack... i dnt have it anymore cause i got a thule basket now... hope this kinda help
  9. Apr 26, 2010 at 6:10 AM
    inlinejohn
    Washington
    hmmmmm. Seems that it sits pretty steep. My thoughts were something more curved, but thanks for pic. Any more pics? Truck looks good. What fogs are those? Where did you get?
