Stock Roof rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SpaceMonkey, Jan 22, 2010.
  1. Jan 22, 2010 at 10:14 PM
    SpaceMonkey
    SpaceMonkey [OP] Well-Known Member
    Houston, Tx
    06 PreRunner
    I like the look of the OEM roof rack but only with the rails across, not stowed. For those that have this rack, does it make much wind noise in either position? I'm wondering why most people don't set up the bars across like this TN member:
  2. Jan 22, 2010 at 10:15 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    A thread on this.... really???
    :confused:
  3. Jan 22, 2010 at 10:18 PM
    SpaceMonkey
    Houston, Tx
    06 PreRunner
    Before dropping $200 on something, I'd like to research it a little. What's your problem?
  4. Jan 22, 2010 at 10:24 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    I don't have a problem I just don't get it.
    If you want an answer to your question though, I don't have the rack but I've ridden in a truck with one and it's very quiet with the bars stowed or extended. It doesn't have nearly the noise that an aftermarket Thule or Yakima rack would.
    Sorry for the smartass remark. It's late and I'm tired :eek:
  5. Jan 22, 2010 at 10:27 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    In mine, it's noisy when not stowed. I don't know if others have the same experience.
  6. Jan 22, 2010 at 10:29 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Thats Mr grimm His truck is sweet. i have wanted the OEM roof rack for a while.
  7. Jan 23, 2010 at 6:17 AM
    sixdoubleseven
    sixdoubleseven Wrangler Convert
    Dave
    Boston
    2014 DC 4x4 Pyrite SR5
    It's a completely valid question. I'm also interested.
  8. Jan 23, 2010 at 6:22 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    x2
  9. Jan 23, 2010 at 6:35 AM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    i've run mine for extended periods with the stowed and with them across... i didn't notice any difference at all. one thing to consider though is that if your running mud tires they will help to disguise any noise as well as the stereo.. i'm sure there is some wind noise from them... just not enough for my deaf ears to hear... :D
  10. Jan 23, 2010 at 11:56 AM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    They are quite noisy in the open position. They don't make any noise in the stowed position.
    Let's put it this way, I left them in the cross position after a lightbar project, and after my wife came home from driving it to work she asked what that horrible sound on the roof was.
    Marc M
  11. Jan 23, 2010 at 12:10 PM
    Griztaco
    Griztaco Well-Known Member
    ID
    TRD
    I presume gas mileage will be better with them stowed, buts that's just a presumption.
  12. Jan 23, 2010 at 12:20 PM
    Reneg8de
    Reneg8de Member
    Tempe, AZ
    05 DC TRD OffRoad 4x4 SR5
    40 Series Exhaust, OEM Roofrack, AFE Stage 2 Si CAI (Pro Dry S), Westin Bed Extender, Heavy Duty Floor Mats, Bridgestone Dueler A/T Revos 265/70R16, USA Spec PA15-Toy iPod Adapter, waiting to install: OME 885s, shocks and LR UCAs
    I have the OEM roof rack and have never had any noise come from it whatsoever. I have always kept mine in the crossways position rather than the stowed position. Furthermore, I've gone pretty fast on country highways (95+ mph) and not noticed any noise from them even then. They work pretty well too by the way and have 2 small hooks on each side of the cab.
  13. Jan 23, 2010 at 6:43 PM
    400lbGorilla
    400lbGorilla ^Son of a hamster, I smell of elderberries.
    T-LAM
    Ocean City, MD
    BSP 4X4 BASE
    Roof Rack, TRD exhaust, Hood Shield, Side Steps, 5% Tints, Tow Package, Bed Extender, Billies at 2.5, Toytec TSB AAL, Avid Offroad Bar, Cruise Control, Removed Sway, Hella 700s, 6000k HIDs, diff breather mod. DTRL, BHLM,Sockmonkyed.
    The dealership installed mine as a selling point, so can't comment on having no rack. But with the bars unfolded I noticed alittle more noise on the interstate. But nothing to be upset with, also if you like the look and function of the wind deflectors, like the yakima, and thule racks have. Inno makes one for OEM racks. it's about $80 and should cut down on any noticable wind noise with the rack unfolded.
  14. Jan 23, 2010 at 6:46 PM
    400lbGorilla
    T-LAM
    Ocean City, MD
    BSP 4X4 BASE
  15. Jan 23, 2010 at 6:51 PM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
    i'm running the yakima rack and i've never heard a single noise from it
  16. Mar 13, 2010 at 6:29 PM
    jmed99
    jmed99 Well-Known Member
    SC
    09 DC PreRunner TRD OR
    Great thread....yes research everything before you buy it for your taco. I just got my Toyota roof rack installed and it does make a good bit of noise from 30 MPH and up. I haven't stowed them yet but hopefully the noise goes away then.
  17. Mar 13, 2010 at 6:45 PM
    jmed99
    SC
    My XM is cutting out a good bit too. The roof rack bar sits right above the antenna. I don't think it would be a problem in the stowed position.
  18. Mar 13, 2010 at 6:48 PM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    TRD Sport+Leather 4x4
    Front 5100's @2.5", Rear 5125's with AAL. Light Racing UCA's, Factory hood deflector, Sirius Sportster 5, TRD air filter, Weathertech's f&r, "Hello Kitty" steering wheel cover.
    I've run mine in the open posistion a time or two and it definitely makes a rumble. IMHO though it is a noise that you would get used to in a short period of time.
  19. Mar 13, 2010 at 7:01 PM
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    Lots of noise, but when folded it up, it shuts up completely.
    I also get crap reception from my stock SAT radio when not folded up.
  20. Mar 31, 2010 at 10:32 AM
    inlinejohn
    inlinejohn Well-Known Member
    Washington
    08 Tacoma TRD Sport SR5 4WD LB
    3" spacer/AAL lift, Toyo Open Country MT 265/70R17, Kenwood USB, Truxedo LowPro QT, Grillcraft w TOYOTA emblem...coming soon, Avid Offroading Sliders...coming soon.
    Just bought my Tacoma w roof rack and tried driving to work w bars in cross position.....Made too much noise and I'm sure the noise = drag = less gas mileage. I will drive with them stowed until I need to use them, but I too like the look when in the cross position better.
