Stock Shocks With HD OME Springs?
Discussion in 'Suspension' started by pdubsalot, Feb 2, 2019.
  1. Feb 2, 2019 at 9:56 AM
    pdubsalot
    pdubsalot [OP] Member
    2013 Regular Cab Tacoma
    So I currently have a 2013 regular cab with a camper shell, baja roof rack, and custom wooden sleeping platform with drawers, as you can imagine my stock springs are sagging pretty bad. All in all it's probably around 350 lbs that I carry around daily.
    After doing some research it looks like I'm going to go with OME heavy duty leaf springs to correct the sagging and mitigate all that extra weight.
    My question is, can I install the OME HD springs and not have to replace my stock shocks right away? I understand that there are some potential issues to keeping the shocks like maxing them out going over rough roads and bumps but since I have all that extra weight I thought maybe it wont be such a problem for me in the short term?
    Thanks for the input.
  2. Feb 2, 2019 at 1:24 PM
    Motomandan
    Motomandan Well-Known Member
    Dan
    Mechanicsville MD
    2018 Double Cab TRD offroad
    Redarc brake controller in Caliraised panel with 2 extra switches, Accessorides remote start. Leer Topper w/ Rhino Rack
    rear shocks are cheap $215 a pair. get the Nitrochargers from OME. They are made to perform not to look good at Starbucks. I Love tge Ride of mine
  3. Feb 2, 2019 at 2:45 PM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    No can do. You'll need extended length shocks to pair with the Dakars like the RCD/Bilstein B110's (5100's). The 4600's don't have enough travel.
  4. Feb 2, 2019 at 4:06 PM
    Motomandan
    Dan
    Mechanicsville MD
    That is incorrect information. It is designed for the HD Dakar
  5. Feb 2, 2019 at 6:42 PM
    MadRiverTaco
    Brenden
    Waterbury, VT
    Oh ok, I guess I'm wrong then...good luck with that.
  6. Feb 2, 2019 at 8:48 PM
    Motomandan
    Dan
    Mechanicsville MD
    Well I guess you are more qualified than the engineers at OME (old man emu)
  7. Feb 2, 2019 at 8:49 PM
    Motomandan
    Dan
    Mechanicsville MD
    By the way Mr know it all. OME nitrochargers are not Bilstein 4600s
  8. Feb 2, 2019 at 9:17 PM
    MadRiverTaco
    Brenden
    Waterbury, VT
    Haha wow man it's actually a pretty simple concept that you clearly haven't spent the time to understand. You over extend the OEM shocks because of the added ride height from the Dakars, thus needing to replace them at a much sooner rate than just installing extended length shocks like the B110's or 90021's while you have the rear suspension taken apart.
    I never said they were. Again, you're not informed. The Bilstein 4600's are OEM on the TRD line and are often compared to the 5100's.
    I suggest you spend some time in the suspension sub-forum and stop being a keyboard commando.
    Falldownhard likes this.
  9. Feb 3, 2019 at 6:36 AM
    TVH475
    TVH475 Well-Known Member
    Montrose CO
    To the O/P, yes you can run your oem shocks! You will run a chance of over extending them, possibly tearing them apart, but they will work! Are there better options out there that will work way better with your new spring packs, absolutely! I'm running Dakars w/ toytec shocks & I am very happy with the ride & there ability to handle extra weight! Good luck!
    whatstcp likes this.
  10. Feb 3, 2019 at 6:42 AM
    Motomandan
    Dan
    Mechanicsville MD
    You need to understand OME is not OEM! OME (old man emu) is the company that has engineered and manufactured the Dakar HD Spring packs. I think you mistakenly thought I meant OEM (ORIGINALEQUIPMENT MANUFACTURER) not OME (OLD MAN EMU) http://www.oldmanemu.com.au/
  11. Feb 3, 2019 at 9:16 AM
    pdubsalot
    Thanks for the help dudes, I ended up ordering OME nitrochargers since they're recommended with the HD springs and they didn't break the bank either. Now, will I need extended break lines too?
    Motomandan likes this.
  12. Feb 3, 2019 at 9:17 AM
    TVH475
    Montrose CO
    Good choice! I did not need extended brake lines!
  13. Feb 3, 2019 at 10:13 AM
    Motomandan
    Dan
    Mechanicsville MD
    Get the 3 degree shims. I would order from Headstrong Offroad. Great support
  14. Feb 3, 2019 at 10:17 AM
    Motomandan
    Dan
    Mechanicsville MD
    I guess you disappear when your knowledge is proven wrong!. Spend more time on your truck and less on your keyboard
  15. Feb 3, 2019 at 10:18 AM
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Nope, the shocks will hit their limit before extending far enough to warrant brake lines. I'm running the OME HD pack and OME shocks with no issues on stock lines. Before ordering shims or installing your pack, take some driveline measurements so you have a baseline. Theres a thread on how and what to measure, just search driveline vibrations and it'll probably be the first one to pop up.
  16. Feb 3, 2019 at 12:07 PM
    MadRiverTaco
    Brenden
    Waterbury, VT
    No I certainly didn't. I fucking run OME springs and Dakars you idiot. I meant OEM. Again, you don't know suspension.
  17. Feb 3, 2019 at 12:13 PM
    MadRiverTaco
    Brenden
    Waterbury, VT
    He's asking about extended brake lines and you tell him to order 3 degree shims??? Are you hearing yourself?
    OP: to answer your question, yes, you should get the extended brake lines for piece of mind. You'll want that cable droop there for the scenarios when you're at maximum travel. Also, do NOT spend money on shims before driving post-leaf pack install. You may not even need them. But in the case that you do have the vibes, be sure to measure your drive-line angles as @rollin904 suggested in order to determine which degree shims you need. 3 degrees may or may not be what you need to eliminate the vibrations you might experience.
  18. Feb 4, 2019 at 7:48 AM
    Gfunk123
    Gfunk123 Well-Known Member
    '13 limited taco
    3” level kit front, Dakar HD w/ Billy B110’s, 1.25” spidertrax, 265/70r18 Falken Wildpeaks AT3W
    I ran oem shocks for a couple of weeks and then put on B110’s as they give you a couple more inches of droop over the nitro chargers. BUT you should run extended brake lines w B110’s but not needed w nitros.
  19. Feb 4, 2019 at 9:40 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    What do you plan on for the front? May have a serious stink bug stance.
  20. Feb 4, 2019 at 4:38 PM
    pdubsalot
    Ya I'm assuming the rear will get a substantial lift even with the excess weight, I have some toytec boss adjustable coil overs with SPC upper control arms. The coil overs are currently at their lowest setting so I will have them adjusted accordingly, hopefully that will be enough to level the truck.
