Stock Shocks
Discussion in 'Suspension' started by jhu616, Oct 17, 2011.
  1. Oct 17, 2011 at 6:53 PM
    jhu616
    jhu616 [OP] Well-Known Member
    Tripp
    GA
    08 4x4 6-Speed TRD Off-Road
    Magnaflow Exhaust, Bilstein 5100s, Eibach Coils, Toytec AAL, Black Baja Wheels, Ipod Hookup, Diff breather
    What are the stock shocks on a 2008 4x4 double cab with trd offroad (the one with the mountain on it)? I know they are bilsteins because I have spent a significant amount of time cleaning mud out from under it, but what type? I just got the truck in July and I am interested in leveling out the truck so I need to know if it already has 5100s on it! Thanks
  2. Oct 18, 2011 at 8:27 AM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    yep 4600's, like the 5100's little brother
  3. Oct 18, 2011 at 10:08 AM
    jhu616
    Tripp
    GA
    Yes, they are definitely the blue and yellow ones! Ok then how much difference in terms of ride is there between the 4600s and the 5100s? And if I put a set of four 5100s on the truck, would I need to invest in anything else to make sure nothing gets broke or gets extra stress put on it? Like coils or anything else
    Thanks for the welcome!
  4. Oct 18, 2011 at 2:01 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    if you go with the eibach springs at .85 you will be roughly at 2.5 or less of lift. if you add a 1/2" spacer to the lift to gain the full 3" of lift you will max out your lca adjustment bolts. From there you will need adjustable uca's to put them back in spec.
  5. Oct 18, 2011 at 4:09 PM
    jhu616
    Tripp
    GA
    Ok, thanks for all the input! I think I'm going to go with 5100s all the way around with the front raised 1.75 to get the level for now, and then when I get enough money ill get the toytec coils to get another 1.6in and then an add-a-leaf in the rear. Would this allow me to run a slightly bigger tire (just the 5100s), or would i need something else too?
  6. Oct 26, 2011 at 6:42 PM
    mytoyo2
    mytoyo2 Mytoyo2
    Frank
    va
    08tacoma4x4 5spd 4cyl
    afe cold air intake,tornado fuel miser,body armor front bumper,dual magna flow exhaust,blacked out factory rims and fender flares,baja lights,cooper ATR tires,Gforce,hood scoop,peel n seal bed cover,chrome nerf bars
    can i use the 5100 i want 2 leave my truck at the factory height the factory rears on mine have a plastic upper housing and the ride quality sux
  7. Oct 28, 2011 at 6:48 AM
    itin1200
    itin1200 Member
    Bill
    Pittsburgh, PA
    2004 4x4 TRD XtraCab
    Want to reinforce. In all caps.
    CALL DSM.
    Marco was very supportive in an idiotic (on my end) issue with a simple install.
    Marco and Sonny should provide consulting to American businesses on how to treat a customer.
    They are tops.
    And Ben doesn't work there.
