Stock Skid Plate Weight?
Discussion in 'Armor' started by Ubaderb, Dec 21, 2018.
  1. Dec 21, 2018 at 12:49 PM
    Ubaderb
    Ubaderb [OP] Well-Known Member
    15 Tacoma TRD OR
    I searched with a couple different keywords and couldn't find an answer to my question. I have a totally factory 2015 TRD OR, so I was curious what the weight of the stock plates are to compare with a full set of skids. Thanks!
  2. Jan 8, 2019 at 8:45 PM
    ucdbiendog
    ucdbiendog Well-Known Member
    Reno, NV
    2014 DCSB TRD OR
    Bilstein 6112 + 5160 + Dakar MD, Stubbs HD-SKO sliders, BAMF skids, BAMF front bumper, Relentless Rear
    tbh its not a skid plate. it's a mud guard. might as well be plastic
  3. Jan 15, 2019 at 9:40 AM
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
  4. Jan 15, 2019 at 9:53 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    The aluminum ones that came on the TRD packages are like 5-10 lbs .. pretty light
  5. Jan 24, 2019 at 3:56 PM
    DarinL
    DarinL Well-Known Member
    Darin
    2017 Tacoma 4x4 TRD 4-dr longbox
    Agreed, it's not a skid plate - grass and gravel deflector at best. Even a tall gopher would put a dent in it at low speeds. The 5-10lb estimate is fair and negligible if you are trying to calculate future front end weight differences going from stock deflector to aftermarket armor.
  6. Jan 31, 2019 at 7:38 AM
    Sootytom
    Sootytom Well-Known Member
    Tom
    I just replaced my stock crappy skids yesterday with 3/16" steel Mobtown skids. The 2 Toyota skids on the OR weight <8 lbs, they're thin stamped sheet metal. Worthless for protection
    I also did the exhaust reroute to clean up the bottom.
    jowybyo and TAC1 like this.
  7. Nov 14, 2019 at 11:02 AM
    TAC1
    TAC1 Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello,
    I just completed my exhaust reroute as well. How much weight do the skid plates add? Suspension sag? Did you go with steel or aluminum?
    Thank you
  8. Nov 14, 2019 at 12:11 PM
    Sootytom
    Tom
    Why are you adding skids?
    For show or protection?
    I’m looking for maximum protection. Steel.
    Aluminum is $$ and not as strong and a little lighter.
    TAC1 likes this.
  9. Nov 14, 2019 at 12:13 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Protection. I don't off-road a lot on rocky areas but it just takes one bad hit to damage something.
  10. Nov 20, 2019 at 10:05 AM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    That's pretty much the reason I run aluminum. I do wheel with it quite a bit - and it takes some hits - but it's not like I'm doing Rubicon anytime soon. They're just there for insurance, and half the weight of steel.
    Plus it's one less thing on my truck to rust.
    Kings, jowybyo and TAC1[QUOTED] like this.
  11. Nov 20, 2019 at 7:00 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Good point on rust, or lack of. :thumbsup:
  12. Nov 21, 2019 at 5:14 PM
    Kings
    Kings Well-Known Member
    Cole
    Ontario, Canada
    2018 Tacoma TRD OR MGM
    17x8.5 SCS Ray 10s, 265/70/17 BFGoodrich KO2s, 2.5" ADS Ext. Travel coil-overs and shocks with compression adjusters, ICON tubular Delta Joint UCAs, Extended brake lines front and rear, OME medium duty Dakar leaf pack, Locked Offroad hydraulic rear bump stops
    +1 for this. Aluminum will protect it while still letting me keep the weight down.
    Aluminum will kinda stick to any rocks though if that makes sense? Steel kinda just slides off. Something to consider also.
    Edit: Spelling
    TAC1 likes this.
  13. Nov 22, 2019 at 5:40 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    That does make sense.
