Stock sport capability
Discussion in '3rd Gen. Tacomas (2016-2023)' started by yoshitanoshi, Nov 7, 2018.
  1. Nov 7, 2018 at 1:11 PM
    yoshitanoshi
    yoshitanoshi [OP] Well-Known Member
    Hey all,
    Had a random question for you guys, I'm looking to take a road trip from NYC area to Utah, CO, and Arizona.
    I'm just wondering how "off road" the sport can go or if anyone has any suggestions of places to go?
    The trip is primarily to see the desert and just explore. Were hoping to camp while out there in the middle of nowhere and see some great sights!
    Could have been worded better, but this is the jist of it .Not looking to go crawling or anything close to that, something tame with great views that the taco can handle
  2. Nov 7, 2018 at 1:12 PM
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    You can do all of that with the sport 4x4, make sure you have good tires and some recovery gear if needed.
    BSFord, shakerhood, phsycle and 3 others like this.
  3. Nov 7, 2018 at 1:15 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    All Tacos are more capable than given credit for.
    If you are going to be in the desert, be sure to have a set of traction boards.
    shakerhood, phsycle and BassAckwards like this.
  4. Nov 7, 2018 at 1:16 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    DeltaBravo and tonered like this.
  5. Nov 7, 2018 at 1:18 PM
    phsycle
    phsycle Well-Known Member
    CA
    Just make sure you've got good tires. Don't venture too far off road unless you're sure of yourself, or you've got other vehicles in the group.
    Stock trucks can go on a ton of trails. I've ventured on plenty of the trails without needing a locker. Just high-clearance and 4WD will get you to a lot of places. You will have a ton of fun.
    tonered likes this.
  6. Nov 7, 2018 at 1:31 PM
    yoshitanoshi
    Thanks guys! Do you think I'd be screwed with the stock sport tires? Not looking to do anything crazy.. ie sand and some rocky inclines?
    tonered likes this.
  7. Nov 7, 2018 at 1:40 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Which ones do you have? The 2017s (at least) came with either Toyo A30s, Goodyear Wranglers?, or Firestone Destinations. I have been pleased with the Toyos offroad for a stock tire. I won't use it again though. The Firestones do not look like a good offroad tire, more like a passenger car tread, IMHO.
    shakerhood likes this.
  8. Nov 7, 2018 at 1:40 PM
    BrettsMac08
    BrettsMac08 Well-Known Member
    Kansas
    2016 DCSB TRD Sport | 2002 Camaro SS
    KDMax Tuned | MagnaFlow Exhaust | OEM Audio Plus Reference 450Q | TRD Pro Wheels | AT Tires | LED Interior Lighting
    I’ve been on some moderate rated trails in my sport and had no issues so far. Went pretty far up Mt. Antero in it and It was a blast.
    But, the only modification I do have are some AT tires and that can make a large difference.
    The stock sport tires are more or less highway tires and I know from experience that they don’t like mud and sand much. Didn’t get stuck but had to really get on the gas a few times on the backroads before I got AT’s put on.
    Some rocky inclines in 4x4 or 4 low should be no issue. Sand you may want to air down for and be cautious in for sure. And definitely get that compressor. I have the same one as above and used it to air up and down on some of the really sharp rock areas and it did great.
    Otherwise I mostly kept it around 30psi for clearance reasons and did fine minus one ding on the exhaust pipe where it crosses under the cab.
    But it’s far more capable than you’d expect. I’d venture to say it will tackle more things then you’d be comfortable with in the first place. At least that’s true for me.
  9. Nov 7, 2018 at 1:44 PM
    CRCs Reality
    CRCs Reality Well-Known Member
    Pittsburgh-Ish
    2017 DCSB TRD Sport (OVTuned)
    This subject always cracks me up. I grew up in the Colorado mountains, and drove my '85 Toyota SR5 Extra-Cab up trails you wouldn't imagine. No lift, open axles, no traction control or Crawl Control.
    Driven carefully and picking the right track, these trucks can go some great places. Just be aware of your capabilities, and have a friend and recovery gear (or at least the recovery gear) and you won't be disappointed.
    PS - Not knocking the locker, TC, or CC. Those are great additions, but bone stock these trucks are plenty capable.
  10. Nov 7, 2018 at 1:45 PM
    Nockturno
    Nockturno Well-Known Member
    2017 MGM Tacoma TRD Sport, DCSB, 6MT
    Your safest best to avoid getting stuck, slow and steady. Completely stock with factory Toyos for the sport, I've done mud, water, rocks, and wet rocks. On trails with others, will go on 4HI and they'll spin tires, I always go 4LO and I have yet to spin a tire, lose traction, or get stuck.
    As everyone said above, way more capable that you may think.
    TacoManOne, CRCs Reality and tonered like this.
  11. Nov 7, 2018 at 2:02 PM
    Wsteven
    Wsteven Well-Known Member
    2018 Tacoma TRD Pro
    Working on them
    There are a lot of Fantastic trails and locations you can do mild off road and get into great camping spots along the way, much of it will depend on how much time you plan to do the trip in and when Idaho has a lot of Excellent locations and so does Utah do your research for BLM location and you will be able to find lots of good spots that are free camping with low pressure of others being there. make sure your tires are good stock tires will work for a lot just carry a tire repair kit (learn how to use it first) and small 12 volt air compressor.
    Be aware of Cellular coverage many location you may not have any so it is harder to get out of trouble if alone just you and your rig not with others and their rigs, Pay attention to the weather hard rains could make easy off the beaten path road a mess and not so easy.
  12. Nov 7, 2018 at 4:23 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    Listen to the OR guys and you'll wonder if you can even make it to the mailbox and back. You'll need 4low for speed bumps!
  13. Nov 7, 2018 at 4:25 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Depends on where your mailbox is really...lol.
    Seriously though, the truck will go further than you probably are willing to take it.
  14. Nov 7, 2018 at 4:48 PM
    tincup33
    tincup33 Well-Known Member
    Beaverton, OR
    2021 TRD S AG DCSB
    The skewp seems to bunch up a lot of panties for those who don't have one so I guess that's one capability.
    Mycroft90 and tonered like this.
  15. Nov 7, 2018 at 4:49 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Exactly. 90% driver, 10% vehicle.
    tonered likes this.
  16. Nov 7, 2018 at 4:55 PM
    tguil
    tguil Well-Known Member
    Nebraska
    2018 Double Cab TRD Sport 4X4 AT
    Get a good set of not too aggressive all terrain tires. I have had very good luck with Michellin LTX/AT2's. Very good on the highway and on backcountry roads and trails.
    tonered likes this.
  17. Nov 7, 2018 at 5:51 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    Sounds like you're fine completely stock. Although, a good set of all-terrains will inspire confidence and make things a little easier on you.
    tonered likes this.
  18. Nov 7, 2018 at 6:10 PM
    Lt. Dangle
    Ohio
    tonered and shakerhood like this.
  19. Nov 7, 2018 at 6:40 PM
    CRCs Reality
    Pittsburgh-Ish
    PS - let me know where in CO you'll be, I can send you on some trails your Tacoma will be great at, but will be awesome to explore :) (As can many others here)
    usernotfound likes this.
