Stock springs
Discussion in 'Suspension' started by mrlooney88, Sep 2, 2011.
  1. Sep 2, 2011 at 2:40 PM
    mrlooney88
    mrlooney88 [OP] Well-Known Member
    Ohio
    '10 d/c sr5 4x4
    Does anyone know which stock spring goes on what side. One has a blue and white mark and the other has a green and white mark. I forgot to mark which side was what.
  2. Sep 2, 2011 at 7:30 PM
    mrlooney88
    Ohio
    '10 d/c sr5 4x4
    Anyone have any idea?
  3. Sep 3, 2011 at 3:31 AM
    mrlooney88
    Ohio
    '10 d/c sr5 4x4
  4. Sep 3, 2011 at 4:03 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    You talking about the coils up front?
    If so it shouldnt matter what side they go on.
  5. Sep 3, 2011 at 9:16 AM
    mrlooney88
    Ohio
    '10 d/c sr5 4x4
    Yes the one up front. Someone told me they were side specific. If get them backwards the taco lean would be worse. They do look to be different lengths.
  6. Sep 3, 2011 at 11:25 AM
    mrlooney88
    Ohio
    '10 d/c sr5 4x4
    I have 5100's up front.
  7. Sep 3, 2011 at 12:12 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    I beleave you are correct. Just checked my '11 AC and all I saw was black.
    Try searching suspension For Front coil replacement. Or ask Toytec which side the Taco lean spacer goes on and put the longer coil on that side. If all else fails PM chris4x4.
  8. Sep 3, 2011 at 1:28 PM
    mrlooney88
    Ohio
    '10 d/c sr5 4x4
    Thanks for looking. The paint must be on the inside of the coil. I might send chris4x4 a pm and see if he knows.
  9. Sep 3, 2011 at 1:30 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The stock coils are side specific , unfortunately I am not sure which goes on which side
  10. Sep 3, 2011 at 1:34 PM
    OZ-T
    Peter North
    British Columbia
    IIRC , the driver's side stock coil should be a bit longer than the passenger side . Do you have them out of the truck ?
  11. Sep 3, 2011 at 3:41 PM
    4Wheelin4Banger
    Randy
    That's what I thought but wasn't sure. I looked into a lift but not ready to do it yet. Searched Taco Lean and every one says driver side so put longer coil on driver side.
  12. Sep 3, 2011 at 3:57 PM
    mrlooney88
    Ohio
    '10 d/c sr5 4x4
    Thanks guys. That's what I was thinking.
  13. Sep 3, 2011 at 4:35 PM
    fatty ac1d
    fatty ac1d Well-Known Member
    Kansas
    15 MGM DCSB SR5
    On mine, it looked like there was a blue and white stripe on both sides. Then there's a red stripe below that on the driver side and an orange stripe on the passenger side.
    :notsure:
  14. Sep 3, 2011 at 9:13 PM
    mrlooney88
    Ohio
    '10 d/c sr5 4x4
    I'll have to look at mine again. That sounds like it might be right.
  15. Sep 4, 2011 at 8:12 PM
    mrlooney88
    Ohio
    '10 d/c sr5 4x4
    Well checked mine and all I found was one has a green and grey mark and the other has a blue and white mark. One is a little longer. Please help me figure this out!!! LOL!!!
  16. Sep 5, 2011 at 9:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    IIRC, The Green is the driver side.
  17. Sep 5, 2011 at 10:03 AM
    mrlooney88
    Ohio
    '10 d/c sr5 4x4
    Ah. Everyone said you would know the answer. Should have pmed you Friday. Thanks. The green one would be slightly longer right?
  18. Sep 5, 2011 at 10:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not all the time. They can be very close to the same length, but the winds of the spring are slightly different.
  19. Sep 5, 2011 at 10:14 AM
    mrlooney88
    Ohio
    '10 d/c sr5 4x4
    Yes I see what your talking about. The green one seems to be, would you say compressed a little more than the blue one. This all would be the same on a sr5 and a trd? I have a sr5.
  20. Sep 5, 2011 at 10:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Make sure the green one is the same height, or a tad longer.
