Stock Supension Measurement 2nd Gen.
Discussion in 'Suspension' started by nvdeserted, Nov 6, 2010.
  1. Nov 6, 2010 at 5:50 PM
    nvdeserted
    nvdeserted [OP] Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Stock/unmodified-suspension 2nd gen Tacoma owners, please post your suspension measurements and year/mileage of your truck. Please measure from the center of your wheel, straight up to the bottom edge of your fender; preferably at all 4 corners. Also list if you have any heavy accessories: winch, full tool-box, etc. Most likely your drivers front will be the shortes measurement: Taco lean.
    Since most of us seem to lift our rigs without first measurnig the stock height we end up not knowing exactly how much our lift gave us. We can go to the dealer and measure a new one, but those springs haven't necessarily settled yet and could make for ann innacurate comparison.
    The reason I ask for the year/mileage is so we can account for settling of springs. This could also be useful for stock-Taco-owners with higher mileages to determine if it's time for new springs.
    Ultimately, after we get a bunch on here I will find the average stock ride height and we can just start using that as a refrence for our lift height.
    I'm guessing the stock height is between 20" and 21" in front and 22-23 in the rear, but let's find out.
    Like this example:
    2005, 100k miles, winch on front
    DF20" PF20"
    DR22" PR22"
    Thanks in advance to those willing to participate.
    Malinosan and mrlee like this.
  2. Nov 6, 2010 at 10:19 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I would love to but my measurements are crap. I would love to have some accurate ones though.
  3. Nov 7, 2010 at 12:41 PM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    Here are my numbers:
    DF: 35.125" PF: 35.5"
    DR: 37" PR: 37.25"
    Edit to add the following:
    DF: 20.5" PF: 20.5"
    DR: 21.625" PR: 21.75"
    Couple of notes:
    - Gas tank is almost full.
    - Toolbox is heavier on driver side, probably 70 lb.
    - Shocks are 5100's all around. Fronts set to 0" lift using stick coils.
    - I have factory-installed AAL with overload leaf (3 leaves + overload leaf).
    - Truck has 81880 km on it.
    Malinosan likes this.
  4. Nov 7, 2010 at 12:57 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    All's I have is from the ground through the hub to the weel arch. Front was 34 3/4" on drivers side, 35" on the passenger side. Back was 37" for both.
  5. Nov 7, 2010 at 2:32 PM
    nvdeserted
    Reno, NV
    Good so far, thanks guys!
    Just to make this a bit easier, if you can measure from the center of the hub up to the fender-edge it helps to cut out variables like: tire size, tread wear, and tire-psi.
    Great start, thanks
  6. Nov 26, 2010 at 10:50 AM
    nvdeserted
    Reno, NV
    Bump. c'mon, I know you just had your 2nd turkey sandwich and need an excuse to dip out on the family for a min. Let s get a few more measurements.
  7. Nov 27, 2010 at 11:35 AM
    SadManGrin
    SadManGrin Active Member
    46 miles on the odometer
    stock, no TSB
    empty cabin, empty bed
    full tank of gas
    Driver Front 20'' Passenger Front 20''
    Driver Rear 21 3/4'' Passenger Front 22''
    I took measurements from the center of the centercaps to the bottom edge/bend of the fender three times.
    I'm not sure how much it'll settle or break in; if it does, I'll find out.
    One of these days I'll get around to a spindle lift with 285s, but for now, stock height is good.
    Regards.
  8. Nov 27, 2010 at 11:49 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    NVD ,
    Front driver's 20 "
    Front passenger's 20 1/2"
    Rear driver's 21 1/2"
    Rear passenger's 21 1/2"
    38 000 kms
    1/4 tank of fuel
    Note : I have the 4 leaf ( TSB ) rear , but they have settled due to carrying a heavy toolbox and lumber . Also the truck has 2 feet of snow in the box right now . :)
  9. Dec 1, 2010 at 8:09 PM
    HarryTaco
    HarryTaco Well-Known Member
    Pacific NW
    2016 TRD OR DCSB 4x4 V6 MGM
    Bed Mat, Bak Revolver Tonneau,
    Bone stock.
    Driver front 20.5
    Passenger front 20.5
    Driver rear 21.25
    Passenger rear 21.25
  10. Dec 2, 2010 at 7:04 PM
    TacoBow
    TacoBow Intentionally cosmetically correct.
    Central PA
    2015 Tacoma TRD Sport 4x4 Quad LB
    Well, I've got old numbers, but can't give you the hub center to wheel opening since the truck is currently on jack stands awaiting the stock rims return from the powdercoater.
    These measurements were taken with the truck on level ground, taped from the rim bead, straight up through the center of the hub, to the inside edge of the wheel opening;
    2006 V6 TRD Access Cab 4x4
    52,000 miles on the clock
    Bone stock, no rear spring TSB
    Cab vacant, bed empty
    3/4 tank of gasoline
    Driver Front 28.5''
    Passenger Front 29''
    Driver Rear 30.5''
    Passenger Rear 31''
    I've measured other ways in the past, (from the ground and from the center of the rim to the fender flare), but found this method the most repeatable.
  11. Dec 3, 2010 at 6:51 AM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    I just measured mine yesterday, before it went to the shop for a lift install. It is stock, with 245-75-16 tires that are new. The rear from the ground to the bottom of the flare is 34 ",this is with about 500 pounds in the rear. The fronts were just a little higher, at 34.5" on both sides. We are supposed to get the truck back today and will re-measure for the difference before and after. It is getting the Toytec AAL in the rear with 5100's and a set of TRD Off Road coils in the front with the 5100's set on 2.5"
  12. Dec 3, 2010 at 7:48 AM
    fatty ac1d
    fatty ac1d Well-Known Member
    Kansas
    15 MGM DCSB SR5
    Driver Front: 20 1/4
    Passenger Front: 20 3/4
    Driver Rear: 22
    Passenger Rear: 22
    38500 miles
    1/4 tank of gas
    Bed empty
    Stock suspension
    2006 Double Cab TRD Off Road
  13. Mar 22, 2015 at 5:39 AM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
  14. Apr 5, 2015 at 10:13 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    2009 4x4, double cab short bed. TSB springs, 55K miles. I carry 300 lbs over stock all times. Suspension is beat...
    Driver Front: 20"
    Passenger Front: 20 3/4"
    Driver rear: 20 3/4"
    Passenger Rear: 21"
  15. May 19, 2016 at 12:11 PM
    ssmith0480
    ssmith0480 Well-Known Member
    Shaun
    Ringgold, GA
    2019 TRD Offroad
    Extended travel Kings, 650 coils Tundra Kings rear Icon AAL with 1/2” shim & Firestone airbags Total Chaos UCA’s ARB onboard air VTX Stinger 17x9 -25 offset Yokohama g003 MT 295/70/17’s RCI roof rack and bed rack TRD Pro skid TRD Pro tail lights R4T high clearance exhaust CBI Baja bumper Smittybilt xrc 9500 winch Dobinsons snorkel, Syklone precleaner Caliraised ditch lights, rigid covers 5.29 gears CVT Mt. Washington RTT Body Armor sliders ECGS bushing
    2013 Tacoma DCSB TRD Offroad, 50,000 miles. Stock.
    All measurements center of hub to bottom of fender flare.
    Front Driver 20"
    Front passenger 20.5"
    Rear driver 21.125" (21 1/8)
    Rear passenger 21.75" (21 3/4)
    So for my front... was the passenger side just high, or was the driver side low? Should I just split the difference and say the front was 20 1/4" when measuring lift gains from coilovers? Or should all lift height be calculated from the 20" driver front measurement?
  16. Jun 10, 2016 at 11:13 PM
    Mountain
    Mountain Well-Known Member
    Revelstoke BC
    15 Acess Cab TRD
    2015 Acess cab TRD offroad 48,000 KM stock springs and shocks.
    All Pro Apex front bumper and Leer 100xr canopy. Unloaded with unknown fuel level when measured. Also have ride rite air bags but deflated for measurements, usually have 10-15psi which brings the rear to around 22" and keeps me from nailing the bumpstops all the time.
    Front D19.5" / P19.5"
    Rear D21.25/P21.75"
    6112's or Fox 2.0's soon most likely for the front.
    Eventually pairing with Ironman 2" leafs and either Billy 5125(P#33-230337) or Fox 2.0(P#980-24-679)
  17. Jan 12, 2021 at 10:34 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Can someone give me the stock measurement not from hub to fender but from the center of the lower shock mount to the flat top of the frame mounted coil bucket with weight on? (Ride height)
    My fenders are cut so hub to fender isn't going to work for comparison but I want to see how much actual lift these have given me.
  18. Jan 22, 2021 at 6:57 AM
    Dex__43
    Dex__43 Well-Known Member
    Sam
    KCMO
    09 DCSB TRD OR 4x4 Swap
    4x4 Conversion 2.5 inch lifts with 33's Sliders Skids Front Runner racks Satoshi grill Patches and Stickers BAMF hybrid front HC tube rear Light bar 2 Hella's behind the grill Pioneer media player and subs Sleeping platform with lower storage for the bed
    How much did you chop your fenders?
  19. Jan 22, 2021 at 7:25 AM
    Key-Rei
    Key
    Florida
    About 1.5"
  20. Feb 9, 2021 at 6:25 AM
    Cougartaco
    Cougartaco Do these tires make my butt look big?
    Cory
    Eastern Washington
    05 SR5 DCSB
    Custom BDS 7.75 lift w/ Fox 2.5 remote reservoir coil overs, eibach 700lb springs Fox rear shocks, BDS UCA, DirtKing LCA, StopTech big break kit front, StopTech big break disc conversion rear, Sequia booster swap, 18” fuel wheel & 35x12.50 Maxxis MT’s, Nitro 5:29 gears, ARB air lockers front & Back, Nitro rear axles, RCV front cv axles, Tom Woods custom 1 piece Driveline, Tyger sliders, FabFour rear bumper, Magnum front bumper w/4 led pods and 24” led bar, Alphamax Nova w/DTR conversion headlights, 12000 lb Remote winch w/factor55 Ultrahook, Cali Raised complete Bed Molle System, Cali Raised bed rail stiffeners, Interior roof Molle rack, AJT control & shifter knobs, Custom black & red leather interior with heated and cooled seats, front cab mount chop, TRD sway bar conversion, custom skids plates, much much more.
    I have a question that I thought would fit into this thread aswell as make for an interesting conversation. I bought my taco several years ago. When I did I was told that it had a suspension lift but he didn’t know what kind. Based on all my research I assumed it was just a leveler kit. Had the front strut(?don’t know if that is correct name for stock suspension) spacer and I thought stock rear spring. It’s has a 3 pack w/over load(total 4). I have read everywhere that they come stock with either 3 or 4 leaf pack so that was of no help. Anyways fast forward to a couple of month ago. I put a BDS 6” lift with the 2.5 fox coil overs with remote reservoirs on my truck. Per convos with accutune I also replaced the coils with 650 lb springs. I also replaced the UCA’s with the BDS ones made for their 6” lift. I also have a magnum RT steel bumper w/12000 lb winch. I am extremely happy with this set up.
    Here is my issue. Due to a combo of slippage/axel wrap my lower drive line came out of the slip yoke(again don’t know if that is what it’s called). When I put it back together I realized it’s only in about 1 inch. This was rectified by a Tom Woods drive line.
    That was all the back story so you know where I am coming from and what made me start questioning what’s going on with my truck. I have been confused by the “center of hub to fender” measurements everyone has been posting.
    My measurements are:
    Front Both sides:25 5/8”(they accounted for the taco lean already)
    Rear both sides: 27 3/4”
    Based on everyone’s measurements my front is correct assuming the 3/8” drop is from bumper weight. I ordered 700lb springs to compemsat for the weight but am waiting to install until my Other parts come in so I can do it all at once.(dirt logic LCA’s, SOS performance front big break &rear disc conversion kits that I already ordered) this way I can use the preload to raise front level instead of compensating for the weight. BUT, I want to figure out rear while I’m waiting.
    Based on everyones info my rear should be at 26” (22 stock + 4 for lift block)” which means I’m sitting 1 3/4 to high? Im not to concerned I just want to know for information purposes. I included a pic so you can see how it sits)
    So, all that to ask- do I have lifted or stock springs? or am I just losing my mind?
    Thanks for any help, info, or even thoughts!!
    Info so you can make an informed answer-
    2005 DCSB TRD OffRoad w/ manual Trans
    Fab steel rear bumper, steel sliders/steps, steel magnum front bumper w/ winch @lights.
    6” BDS lift w/ fox coil overs, 35” tires on 18”wheels.
    Geeves77 and ohcaltexscar like this.
