Stock suspension and washboard roads
Discussion in '1st Gen. Tacomas (1995-2004)' started by Nessal, Sep 5, 2021.
  1. Sep 5, 2021 at 4:44 PM
    Nessal
    Nessal [OP] Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Hi all, I have a trip to Death Valley coming up and I read that the washboard roads are no joke and will rattle your truck apart. There is a stretch of road that I will be on that is 40 miles of washboard roads. My truck is completely stock and the suspension is original(2003 TRD 4X4) but still functional and will be carrying about a 500lb load in the bed with 3 total passengers.
    Do you think it would be OK on stock suspension? If not, what do you suggest? I've read a thread here where people said that the Bilstein 5100 is horrible on washboards. TIA!
    prerunnerSD likes this.
  2. Sep 5, 2021 at 4:49 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Something like this I have found there is always a sweet spot you just need to find it. which changes because of so many variables .
    Now if this is a excuse to upgrade the suspension by all means go for it
    Jojee117 likes this.
  3. Sep 5, 2021 at 4:51 PM
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    If its anything like the local washboards here, either go real slow or speed up until it smooths out. Any reasonable speed will infact rattle your truck apart. It was miserable with my stock suspension, but my aftermarket isnt much better. All I can suggest if you're looking for aftermarket suspension is avoid ironman. I'm guessing whatever route you go, you will also want soft springs. If you have a heavy setup and go with stiff springs to hold it up, good luck.
  4. Sep 5, 2021 at 4:54 PM
    Nessal
    Texas/Bay Area
    Thanks fellas. It's just that with such a old truck we are worried about getting stranded. I've heard of radiator supports cracking, battery tie downs cracking, lights falling off, RTT and bed tack falling off, etc that it's giving me some pause.
  5. Sep 5, 2021 at 5:01 PM
    Bivouac
    Those things can happen just take your time .
    It is not a timed event is it??
    At the wrong speed it sets up a harmonic vibration that can shake almost anything apart.
  6. Sep 5, 2021 at 5:14 PM
    Nessal
    Texas/Bay Area
    Yeah so the issue is that if I drive 10mph.....it will take us 4 hours to cover that ground. Probably not the best use of time. But going faster....we run the risk of the truck falling apart lol. Decisions.
  7. Sep 5, 2021 at 5:26 PM
    Jojee117
    Joe
    MT
    If you can air your tires down it becomes quite a bit more manageable. It's a 40 mile stretch, so I would think it would be worth it to stop and air down. Back when I had my stock suspension (140k miles) I tried airing my tires down to 20psi and I was able to go a respectable 30+ mph without any issues. I didn't try going any faster, but I suspect you could.
  8. Sep 5, 2021 at 5:27 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Drop tire pressure about 10lbs and keep your speed constant
  9. Sep 5, 2021 at 5:39 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Even if you weren't going to death valley, that original suspension was due for replacement over +13 years ago :laughing:
    Nessal[QUOTED][OP] and High Noon like this.
  10. Sep 5, 2021 at 7:48 PM
    Loober
    Loober Well-Known Member
    I know the stretch of road you are talking about in DV, its brutal. No aftermarket suspension will make much diff on stuff like that. Do a good thorough check of your truck before the trip and check all the bolts, especially battery tie downs. Stop and check things over half through and before getting back on the highway, and listen for any new noises. I've dont that stretch many times and am always surprised how the truck stays together, trust in the truck and your prep and have a good time.
    With that said, fix anything that is suspect before going.
    Nessal[OP] and Jojee117 like this.
  11. Sep 6, 2021 at 8:25 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    What stretch is that?
  12. Sep 6, 2021 at 8:43 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Low tire pressure helps the most. A non e load side wall will help too.
  13. Sep 6, 2021 at 8:55 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Is there another route????
    Washboard happens due to interaction between soft ground and vehicle suspension dynamics. The "bumps" occur at a specific frequency. The only thing you can do is alter your speed. You can have a minor impact on the harmonic by playing with tire pressures and weight. But be ready for a long road of tooth filling rattle.
    Washboard roads are very common in Iowa on the gravel (unpaved) roads, worst in the Spring.
  14. Sep 6, 2021 at 9:29 AM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    40 miles of washboards sounds horrible. There would have to be a serious booty call at the other end for me to even think of driving that. If you insist on going just remember that traction on washboards is considerably less. It's real easy to loose it on corners and slide right off the road. Stay safe.
    skeezix and vern650 like this.
  15. Sep 6, 2021 at 4:46 PM
    Loober
    Saline Valley Road as you head out towards 190, some years are worse then others. Its the main way in n out, so its hard to bypass without adding a lot of miles.
    skeezix[QUOTED] likes this.
