Stock suspension information on a 4wd needed
Discussion in 'Suspension' started by 3.4PDM, Apr 20, 2010.
  1. Apr 20, 2010 at 8:35 PM
    3.4PDM
    3.4PDM [OP] Well-Known Member
    The PO of my truck ( 1997 Tacoma 4x4) lifted it by ways of a Skyjacker suspension. The problem is that I do not know exactly what he did so I can just change it back. I am especially interested in knowing what the rear shackles look like and what are the dimensions from top bolt to bottom bolt so i can see if he changed those as well.
    Also, if you could, please tell me the height from bolt to ball joint of the front hub spindles I think he put a taller one in there but Im not sure..
    Any help is appreciated. Thanks!
    peter
  2. Apr 21, 2010 at 10:37 AM
    98tacoma27
    Ben
    Not Beech Creek
  3. Apr 21, 2010 at 10:41 AM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    Just look up skyjacker suspension for your kit. It should tell you about what comes with it. Should be able to contact them to about the install and then just reverse it. I doubt he changed the spindal. Probably just put a extension on it with the drop bracket kit for the truck.
