Stock suspension isn't working well, what is appropriate upgrade for me?
Discussion in 'Suspension' started by aw113sgte, May 5, 2014.
  1. May 5, 2014 at 6:58 AM
    aw113sgte
    aw113sgte [OP] Well-Known Member
    Unfortunately there is basically no offroading near me so most of my driving is street and dirt/gravel roads. When driving on rutted roads, the stock suspension allows the truck to skitter around, and generally makes holding a line while driving quickly difficult.
    I wouldn't mind a 2-3" lift, however I mainly want the better suspension compliance/road holding. I don't need more carrying capacity than stock, it does pretty well for my needs.
    This is a 2012 btw.
    I would assume the baja suspension would work well, however I'm not sure if it's actually any good?
    Fox/Icon/King shocks/coilovers?
    Should I be looking at ways to better control the axle motion? Seems like it moves around quite a bit with the stock floppy leaves.
  2. May 5, 2014 at 7:00 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I went with the ironman 2" lift
  3. May 5, 2014 at 11:05 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    How fast do you want to go on the backroads and how rough are they?
  4. May 7, 2014 at 6:19 AM
    TrueNorth
    TrueNorth Well-Known Member
    Maryland
    13' V6 4X4 DCSB
    Weather tech floormats and visors, ImMrYo rear-view mirror bracket Cooper ST Maxx 255/85/16 On stock TRD alloys. OME 887's w/NitroCharger sports, LR uca's, Toytech sway bar relocate, Dakar leaf's modified with some 1/8" UHMW liner strips. SuperBumps front and back.
    There's a sticky in this section. Lift info I think. Great place to start. But if you stiffen up the rear to help with axle wrap your going to get better load capabilities.
    OME with 885's and Dakar rear. Ftw. Or 884's and Dakar with 3rd leaf removed.
  5. May 7, 2014 at 6:33 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Since you're mostly street/dirt/gravel, Bilsteins or OME would fit your needs. Also look into some new UCAs if you'll be running full 3" lift. At first, I did an AAL in the rear and regretted it after 3 months. I now have the Dakars w/ the D29XL additional leaf. Should've run the new leaf pack from the beginning but you live and you learn. I sold my OEM leaf pack with the AAL to a local member who didn't want much lift and I was able to make back some of the money. Both parties are happy :taco:
  6. May 7, 2014 at 6:45 AM
    The109
    The109 Well-Known Member
    Fort Collins
    2013 TRD OR Access Cab
    You could try airing down a bit and see if that helps before you shell out money on a suspension.
