stock suspension pictures
Discussion in '1st Gen. Tacomas (1995-2004)' started by ronnishusband, Jul 5, 2012.
  1. Jul 5, 2012 at 3:53 PM
    ronnishusband
    ronnishusband [OP] New Member
    nc
    98 sr5 4x4
    After months of searching just got a 99 4x4 standard cab...it apears to have a slight lift under it. Maybe 2" or so suspension lift...anyone have pictures of stock suspension (front & rear) to help determine exactly what's been added. The rear shackles are obviously not stock, but the front is less clear to me. I want to return to stock and need to know what stock parts I'm looking for. Thanks in advance for any help.
  2. Jul 5, 2012 at 3:57 PM
    JdevTac
    JdevTac Negative Ghostrider
    Josh
    GA
    2013 DC TRD-OR 4x4 Pyrite Mica
    Do you happen to know what kind of struts are on the front and rear? That information alone would probably help someone on the right track to determine any lift info.
  3. Jul 5, 2012 at 4:01 PM
    scocar
    scocar Purity of essence
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Back to square one after the 2001. So...
    Here are shots of stock, but sagging, leafs (3 plus overload) and shackles.
    Sorry, but I do not have pix of the stock front suspension.
  4. Jul 5, 2012 at 4:11 PM
    ronnishusband
    nc
    98 sr5 4x4
    sorry, I do not know what kind of struts, they may be stock based on the simple appearence of age. But then again I just got the truck and have no idea of the age of the lift.....Thanks sccar for the pictures, you have confirmed what I suspected on the rear shackles, mine are at least twice that length at the bumper end of the leafs, the engine end look to be stock. Thanks again
  5. Jul 5, 2012 at 4:20 PM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    You're welcome.
    Like Ryan said, post some pics of your front suspension, then we'll be able to tell pretty quickly for you. Especaily get a good shot of the top of the coil assemblies.
  6. Jul 5, 2012 at 4:44 PM
    ronnishusband
    nc
    98 sr5 4x4
    duh....sorry new to all this
  7. Jul 5, 2012 at 4:47 PM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    Lift shackles in the rear and coil spring spacers in the front. Looks like a 1.5 inch or so.
  8. Jul 5, 2012 at 6:17 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    ^ x2 also you have EXTREMELY NEW TIRES! haha sharp lookin truck!
    in a related question.. are there any statistics on factory ride height?? like what the average height was for each model Taco (reg/ext/dbl cab) leaving the factory?
    I'm trying to figure out how much lift I gained over "stock" height when I re-did the suspension but only have 10yr old "sag" measurements.
  9. Jul 5, 2012 at 11:04 PM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    Yes, the FSM provides the information to determine this. You need the model ID # off your door jamb sticker, then follow the attached guidance.
  10. Jul 6, 2012 at 12:18 AM
    sportsterchop200
    sportsterchop200 Well-Known Member
    Cental Florida
    03 TRD Tacoma 4x4
    OME 881, Bilstein 5100 @ 0", OME 10mm JK spacer, Stock rear on 265/70-16
    Looks like Daystar shackles on the rear with stock springs. Not sure about the model of front spacer lift.
  11. Jul 6, 2012 at 6:01 AM
    TIPICOTACO
    Tyler
    nw nj
    THANK YOU!!
  12. Jul 14, 2012 at 10:08 PM
    sportsterchop200
    Cental Florida
    03 TRD Tacoma 4x4
    What is "FSM"? The attached charts don't make any sense to me. I'm trying to figure out how much lift I actually got over factory stock also.
    Recently installed 881's with 5100's @ 0" and a 10mm JK spacer. My stock front ground to fender measurement (265/70-16) was 35 13/16" before and 38 1/8 after. My stock measurements seem higher than others that I have read and the truck has 91K on it.
