Stock suspension sagging. OME 881, 883, plate bumper with winch. So confused...
Discussion in '1st Gen. Tacomas (1995-2004)' started by garrettnb, Aug 22, 2013.
  1. Aug 25, 2013 at 5:35 PM
    garrettnb
    garrettnb [OP] Canadian Ambassador
    Garrett
    Vancouver
    00 TRD w/33s on a 4" lift
    I'm so glad you answered the question I asked... I won't be running without a spacer, you can gladly not run a spacer on your truck - but mine will have it due to the 4 inch diff drop.
  2. Aug 25, 2013 at 5:43 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    Why are you so insistent on running the spacer?
    You seem to be doing a lot of research and work only to half-ass the suspension with that spacer.
    FYI, anytime you post a question on any topic, regardless of how specific, be prepared to have people analyze what you are trying to accomplish. Believe it or not, there are some people on here that have a lot of knowledge and want only to help you out.
  3. Aug 25, 2013 at 7:09 PM
    jkirkpatrick
    jkirkpatrick Well-Known Member
    Edmonton
    2000, build thread soon
    Stealth sub box, total stereo overhaul, 883 OME with Nitros, Dakars, All Pro bumper, Engo 10,000lb winch w/ synthetic line, ARB rear locker, All Pro full skids, All Pro sliders, 7069 Pro Comp with 285/75/16 Duratracs, front sway bar delete, CBI rear bumper, regeared 4.88
    I had presumed that with your plans for a bumper, winch, and skids, that you'd want an off road setup. This is why I say to scrap the spacers, and reclaim some ground clearance while installing a proven wheeling setup.
    I'm not sure why sort of end goal you're shooting for by using your existing spacers in conjunction with the 4x4 equipment you listed previously.
    Free bump for you as maybe somebody else can give you some different ideas.
  4. Aug 25, 2013 at 8:34 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    No Truck..well, maybe
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yep & to be clear OP, you keep referencing a diff drop as a lift, do you mean a drop bracket ?? You'd almost have to be with a reference to 4" of lift seeing how 3" is the max with IFS 4x's , true the bracket WILL get you 4" but it also lowers your ground clearance an inch or more IIRC....
    God I hate IFS, solid axle anyday knowing now what i didn't know then about IFS...
  5. Aug 25, 2013 at 9:35 PM
    garrettnb
    Garrett
    Vancouver
    I'm Running the spacer because it's the only way I can make this work, due to the drop bracket. It's not how I would have done the lift if I had done it myself. I would have used a 1 inch drop and gone with some coils which would have done the lifting. But now that things have been cut on this truck - I can't really go back to that.
    Yes I do, I keep mixing up the terms. I do agree as well, I would have saved up and just splurged for a SAS.
  6. Aug 25, 2013 at 10:51 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Yeah, this is my first IFS 4x, I've had full sized Fords , a great run with my 1 ton Power Wagon, had a jeep & my favorite 4x was my '83 Toyota single cab, they all shared 1 thing in common... solid axle, I'll never buy another IFS thats for sure, too many "pussy parts"...:)
