Stock Tacoma with 265/70/17 Pictures Please!
Discussion in 'Wheels & Tires' started by prov1x32, Feb 21, 2019.
  1. Jul 22, 2021 at 4:40 AM
    #161
    Thomas2335
    Thomas2335 Well-Known Member
    FN fx pro ... 17 x 8 ... 0 offset
    Matte Gunmetal
  2. Jul 23, 2021 at 6:07 PM
    #162
    PLYDRTY
    PLYDRTY Well-Known Member
    Jeff
    Haymarket, VA
    17 MGM TRD OR DCSB
    Backspace? Any lift?
  3. Jul 24, 2021 at 7:40 PM
    #163
    NWTFTN
    NWTFTN Member
    Michael
    2017 TRD off-road
    Camper shell, bed slide, shift-sense pro, expeditions essential accessories
    2017 TRD Off-road with Falken wildpeak M/T 255/75x17 All stock on pro rims with no rubbing.IMG_5112.jpgIMG_5106.jpg
  4. Jul 27, 2021 at 3:43 PM
    #164
    Mazddie66
    Mazddie66 Member
    What PSI do you guys run on this size?
  5. Jul 27, 2021 at 3:44 PM
    #165
    98_3RZ_NIC
    98_3RZ_NIC Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    what are your wheel specs!? Looks very nice.
  6. Jul 29, 2021 at 6:14 PM
    #166
    ETBA
    ETBA Well-Known Member
    Erik
    Texas
    2021 TRD Off-Road
    tacoGoVroom and VR812 like this.
  7. Jul 29, 2021 at 6:25 PM
    #167
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    I have LT 265 70 17's and I find 30, 31,32 is a good balance depending on your tread pattern
  8. Jul 29, 2021 at 8:41 PM
    #168
    Mazddie66
    Mazddie66 Member
    Damn I’m at 35… rides well for me but I’ll try to lower it.
  9. Jul 30, 2021 at 6:37 AM
    #169
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Not as much about the ride as how evenly the tire is contacting the ground. A few pounds difference you probably won't notice any ride quality changes.
  10. Jul 30, 2021 at 11:56 AM
    #170
    Steve Armstrong
    Steve Armstrong Well-Known Member
    SoCal
    2021 TRD Sport DCSB
    In my setup, the calculator says 28 psi (OEM psi is 29). I'm running them at 30 psi.
    CaribeTaco likes this.
  11. Aug 2, 2021 at 3:17 PM
    #171
    Nymbus
    Nymbus Well-Known Member
    2021 TRD Offroad DCSB Cement 4x4 AT
  12. Aug 4, 2021 at 5:52 PM
    #172
    Made671
    Made671 Active Member
    2021 Tacoma
    265 70 17 SCS Gen5 -10offset
  13. Aug 8, 2021 at 5:51 AM
    #173
    Fastestinthewest
    Fastestinthewest Well-Known Member
    Austin
    Texas
    2020 Tacoma TRD OR
    Any rubbing? Looking to go the same setup/offset with Wildpeaks.
  14. Aug 8, 2021 at 11:21 AM
    #174
    Made671
    2021 Tacoma
    Rubs only the on front spoiler that I've notice.. I have a sport.. but not that bad only happened to me a hand full of times. Only going into steep driveways while turning. Planning on removing it though just haven't gotten around to it since it's not a big deal
  15. Aug 26, 2021 at 3:48 PM
    #175
    NightTaco
    NightTaco Member
    2019 SR5
    What’s the offset? I’m getting this tire size and same tire but I’m still a little confused about the offsets
  16. Aug 27, 2021 at 10:01 AM
    #176
    yotayoke
    yotayoke New Member
    James
    2011 DBL Cab TRD Off Road
    I really dig this, I have a 2011 silver dbl cab and am looking to get wheels. Those are the TRD wheels with just different center caps right? Where did you get the caps? Looks clean
  17. Aug 27, 2021 at 3:59 PM
    #177
    spuntron
    spuntron Member
    2019 MGM Tacoma Sport
    Raceline Defenders 0 offset
    Stock with Raceline Defenders with 0 offset and 265/70/17. Just got'em today after 2 years owning the truck. I'll take some better pictures once the Caldor Fire haze goes away and I wash it.
    PXL_20210827_194530171.jpg PXL_20210827_194556284.jpg PXL_20210827_194544138.jpg
  18. Sep 10, 2021 at 1:43 PM
    #178
    martymart2u
    martymart2u New Member
    2021 Tacoma TRD SPORT
    What tires are you using and do you have a lift?
  19. Sep 10, 2021 at 4:30 PM
    #179
    Fedup13
    Fedup13 Well-Known Member
    San Diego
    2021 OR DCSB 4x4
    Mine rub slightly back end of fender only in reverse when turning
  20. Sep 10, 2021 at 4:31 PM
    #180
    Fedup13
    San Diego
    2021 OR DCSB 4x4
    Look like K02’s
