Stock Tacomas!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ferraperez, May 23, 2014.
  1. May 24, 2014 at 7:26 PM
    #41
    luvium
    luvium Well-Known Member
    San Diego
    13 DCSB 4x4 TRD Offroad M.G
    Trimmed front flaps Extra D rings
    x1 out in the desert, put it through some nasty spots and never had a problem, i think ground clearance is the big issue with stock.
  2. May 24, 2014 at 8:56 PM
    #42
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    back when mine was stock, and really its not hardly different from stock now sans tires, springs, and shocks.
  3. May 24, 2014 at 9:02 PM
    #43
    deeppowder
    deeppowder Well-Known Member
    Northern San Juan Mountains
    2014 trd dcsb
    Just wondering what you where hitting? Certainly the mud flaps will hit on anything but I've done a few trails and only hit my soon to replaced flaps.
  4. May 25, 2014 at 3:57 PM
    #44
    rvdb
    rvdb Well-Known Member
    CA
    TRD Sport
    stuff that makes it better for my use...
    I was tagging the exhaust/crossover, and yes the mud flaps hit everything...
  5. May 25, 2014 at 4:03 PM
    #45
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I feel stock ..but I have a 2 in lift on my truck.. everyone else around here is 3 or higher...
  6. May 25, 2014 at 5:55 PM
    #46
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    You may want to consult a doctor ;)
  7. May 25, 2014 at 6:00 PM
    #47
    smmarine
    Melbourne FL
    I can make it through some pretty soft sand in my 2wd. Detroit Truetrac, 10 PSI, and I've stopped in some soft stuff and just pulled right through, and if I can't, I can usually just back right up and try again
  8. May 25, 2014 at 6:38 PM
    #48
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    2014 DCSB TRD Off Road
    A little a this, a little a that...
    You can go really far in a stock Toyota 4x4. Mine is stock for now. Wheeling stock will make you a better driver and cue you in to any mods you might need in order to do what you like to do.
    I always start by striping off anything unnecessary that hangs down. On my 2nd gen that was mud flaps, 7-pin connector and I rerouted the exhaust crossover pipe. After that, tires are the best thing you can do to improve off-road performance.
    Sooner or later you'll need a lift to keep progressing. But with the short wheelbase of a regular cab, that's even less important.
