Stock Tire Life?
Discussion in 'Wheels & Tires' started by Bosmob, Jun 16, 2011.
  1. Jun 16, 2011 at 10:24 PM
    Bosmob
    Bosmob [OP] Well-Known Member
    Kevin
    San Diego, CA
    '11 Access Cab SR5 I4 4AT
    Fat Bob's 2.75" front spacers Magnaflow Muffler Doug Thorley Header ImMrYo Mirror Bracket
    I was just wondering how many miles I should expect my stock Dunlop Grandtrek 215 tires to last?
    I have them set to the PSI specified on the door jamb. (30 Front, 33 Rear) My truck is an Access Cab.
  2. Jun 16, 2011 at 11:24 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Stock Tires:
    Not sure on Dunlops, but the Off Road Tacomas come with BFG Rugged Trails... I have had 3 Tacomas with them... the most they lasted was 25,000 miles... The 2010 Tacoma got rid of them at 20,000 miles... had 2 punctures from sharp rocks by that point... worthless!
  3. Jun 17, 2011 at 6:47 AM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    I replaced mine at 36,000 miles.
  4. Jun 17, 2011 at 7:08 AM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    My stock Dunlops are at 46,000 now and could probably go another 10,000 if they had to. I'm replacing them with some A/Ts in a couple of weeks, I don't want to go through another winter with them.
  5. Jun 17, 2011 at 7:15 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    my dad did strictly freeway miles on his and it was before i had my license so i didnt drive it... hehe :rolleyes" but he got about 60k outta them. the he got some hankook and they went in 20k cause i finally got my license. now he has a different set but i forgot.
  6. Jun 17, 2011 at 7:23 AM
    oldtacomaguy
    Dave
    SE Conn.
    Glad you're not my kid:facepalm:
  7. Jun 17, 2011 at 7:53 AM
    tacokid09
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    hey, i was 16 and stupid. Ive learned to respect things now haha. just took me a little time.
  8. Jun 17, 2011 at 8:10 AM
    Burns
    Burns Excellent Member
    NJ
    17 DCSB Off-Road
    None!
    My dunflops only lasted about 30 to 40k, by far the worst tires I have ever had on any of my vehicles. I would of replaced them sooner but I was being cheap.
  9. Jun 17, 2011 at 8:27 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I replaced mine at 30k miles. Could have gotten more but was heading into winter and they weren't doing well.
    Unless you tow/haul frequently, set the rears down to 30 psi. All the weight is in the front of the truck so there's no need to have the rear tires pumped up that high unless you have some weight back there.
  10. Jun 17, 2011 at 10:11 AM
    Superdavert
    Superdavert Well-Known Member
    Dave
    Athens, Ga
    '09 TRD Sport DC SB
    20" Enkei Deep 6 wheels wrapped in 275/60 20 Hankook Dynapro ATm, ProComp 2" leveling kit, Foglight anytime mod, Sockmonkey TRD Sport bedside decals, Extang Trifecta tonneau cover, Toyota bed extender, Aries black nerf bars, Pop & Lock 8521 Powered tailgate lock
    I have about 25,000 mi on my Dunlops. Saying goodbye to them hopefully soon.
  11. Jun 17, 2011 at 12:06 PM
    Bosmob
    Kevin
    San Diego, CA
    So you're saying just set them at 30 PSI Front and 30 PSI Rear?
  12. Jun 17, 2011 at 12:08 PM
    Pugga
    Massachusetts
    F-150 Mod
    Yep, unless you're towing or hauling regularly. There's more weight on the front tires than the back. Unloaded, the back end is very light so you don't need your tires pumped up that much. 3 lbs won't make much of a difference but it'll help them wear a little more evenly.
    I've got 265/65R17's and I'm at 32 psi front and rear. I typically have an extra 300-350 lbs in the bed of the truck full time. When I was running 245/75R16's, I was at 29-30 psi front and rear. You can also do the chaulk test to see what the ideal pressure for your tires should be. Draw a line of chaulk across the tire, drive for a short distance and see where the chaulk wore off. If it's worn off evenly, you're good, if it's only worn in the center, your pressure is too high, if it's only worn at the edges, your pressure is too low.
  13. Jun 17, 2011 at 12:14 PM
    Mskwared
    Mskwared Well-Known Member
    Got 40k out of mine. Thins were gettin REAL sketchy though in the rain...
  14. Jun 17, 2011 at 12:20 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Rob
    Pacific Northwest
    2005 4x4 DC TRD Off Road
    11 Color Matched Grille, Pro comp 7089s, 265/70/17 Wrangler Duratracs, Black Running Boards, Tinted Windows, Bed mat, Weathertech Floorliners
  15. Jun 17, 2011 at 12:28 PM
    MassTaco
    MassTaco Well-Known Member
    Massachusetts
    V6 4x4 SR5 DC AT5
    I'm right in line with this - 47k miles now and I have about .150" tread depth left. Could go another 10k, but I'll replace them with Firestone Destination A/Ts before next winter. I always run 34 psi in all 4 tires.
  16. Jun 17, 2011 at 8:32 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    At 13K miles, mine were at the replacement indicators. I discovered this when I got stuck in the snow (a few inches of snow at that) and couldn't believe they only lasted 13K miles. My guess is that the high temps on the freeways (when it's 100+ degrees in the summer) wear them down really fast. I don't think we've ever gotten more than 20K out of any of the dunlops that came on Toyotas. Now our '10 highlander seems to be doing a lot better than the ones on the Taco, but I don't expect them to survive to 25K.
    I hear people on here getting 40K, 60K, 80K and I just can't believe it. Many others only got around 13K like me (in past threads on multiple forums), so it's just the luck of the draw as to how long yours will last.
  17. Jun 17, 2011 at 8:36 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    my stock bfg rugged trails are at 65k and still going!
  18. Jun 17, 2011 at 8:36 PM
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
    You owned three Tacomas of the current model? Really? Do you have money left for anything else? :)
