stock to h4 conversion help
Discussion in 'Lighting' started by NickJ*97756, Nov 30, 2010.
  1. Nov 30, 2010 at 9:57 PM
    NickJ*97756
    NickJ*97756 [OP] Well-Known Member
    Nick
    La Grande OR
    95 Red Ext. Cab
    Black Ultra Type 175 Rogue wheels, 33x12.50's, exhaust, sony deck,JL tweeters, hella 500ff's, painted rear bumper, brush guard, tail lights, kc's, custom tube bumper,5100's w/trd springs, toytec aal, custom tire carrier
    I ordered a new set of h4 headlight housings and some PIAA intense white h4 bulbs. What do i need to do to install these bulbs since the sock ones are sealed beam? Thanks
  2. Dec 1, 2010 at 5:15 PM
    NickJ*97756
    Nick
    La Grande OR
    95 Red Ext. Cab
  3. Dec 1, 2010 at 5:16 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    diy section
  4. Dec 1, 2010 at 5:20 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Should be the same as changing a sealed beam headlight. Just have to put the new bulbs in the new housings you bought first. If you are using high wattage bulbs, you might have to upgrade your wiring.
  5. Dec 1, 2010 at 5:48 PM
    NickJ*97756
    Nick
    La Grande OR
    95 Red Ext. Cab
    does anybody have a ddirect link to this? I have a first gen by the way
  6. Dec 1, 2010 at 5:50 PM
    crf69
    Ohio
    ummm yeah
    you def do not know
  7. Dec 1, 2010 at 5:51 PM
    crf69
    Ohio
    ummm yeah
    make and model does not matter..........hid are hid and universal......its pretty easy once you get the set when you look at it
  8. Dec 1, 2010 at 5:52 PM
    NickJ*97756
    Nick
    La Grande OR
    95 Red Ext. Cab
    Will I need to get a new wiring harness?
  9. Dec 1, 2010 at 5:54 PM
    crf69
    Ohio
    ummm yeah
  10. Dec 1, 2010 at 5:56 PM
    crf69
    Ohio
    ummm yeah
    ok wait.........im sorry im a tard..sometimes........you getting what now? HIGH INTENSITYS?
  11. Dec 1, 2010 at 5:56 PM
    NickJ*97756
    Nick
    La Grande OR
    95 Red Ext. Cab
    But the plug on a h4 bulb is different. What do i do since the stock are sealed beam? do i just cut the wires off?
  12. Dec 1, 2010 at 5:57 PM
    NickJ*97756
    Nick
    La Grande OR
    95 Red Ext. Cab
    im getting the h4 piaa intense whites
  13. Dec 1, 2010 at 9:45 PM
    joes06tacoma
    Joe
    Central Coast, CA
    OP: Do you actually have these parts in front of you right now? Have you looked at the connectors on the truck? I assume this is for the 95 you have listed in your avatar?
    I have done this conversion on a 1986 Toyota 4x4. I also sold auto parts for a few years. The 86 uses the same sealed beam light that the 95 tacoma uses. It should be a direct plug in just like my 86 truck was. As long as the wattage isn't more than 55/65 you should be fine with stock wiring. I made a custom harness for my 86 and ran 80/100 watt bulbs. Worked AWESOME. You can buy upgraded harnesses already made up too.
    Can't figure out why you would have to change the wiring? Maybe if you post pics we can help better.
    Edit: If your truck uses a part number H6054 for the stock headlight, then the H4 plug is exactly the same.
  14. Dec 2, 2010 at 9:00 PM
    NickJ*97756
    Nick
    La Grande OR
    95 Red Ext. Cab
    I dont have the parts yet. I looked at my stock lights and the plug will fit the h4. But im getting the PIAA intense white bulbs and they say Wattage60/55w = 135/125w, 4100K
    My question is will have to upgrade the wiring or is the wattage okay?
    Thanks everybody for the help!
  15. Dec 4, 2010 at 4:20 PM
    NickJ*97756
    Nick
    La Grande OR
    95 Red Ext. Cab
    anybody?
