Stock transmission cooler sufficient?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Highpowerrocket, Mar 6, 2016.
  1. Mar 6, 2016 at 7:27 AM
    Highpowerrocket
    Highpowerrocket [OP] New Member
    Good afternoon everyone and thanks in advance for fielding my question.
    I have a 2012 Tacoma Prerunner. V6 2WD with the factory tow package.
    I am buying a trailer (my first) 7x14 utility for hauling firewood. So max load about 6,000lbs including the trailer. Usually less than that. I installed my brake controller and was about to install my Hayden trans cooler when I noticed there was already one mounted to the front of the radiator from the factory. I am now assuming this will be sufficient and I can return the other one. Thoughts?
    It is smaller than the one I bought but looks beefier.
  2. Mar 6, 2016 at 7:42 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I'd leave the stock one and return the one you bought. If anything, to not splice more lines and create more possibilities of a leak.
  3. Mar 6, 2016 at 7:45 AM
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    +1
    Highpowerrocket[OP] likes this.
  4. Mar 6, 2016 at 1:33 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    I installed a Hayden cooler on mine and my trans temps dropped dramatically. I did not have the factory cooler though. I'd guess that it's probably plenty big enough to keep your trans cool. Sometimes I wonder if my trans is TOO cool running at 110-115 around town.
  5. Mar 6, 2016 at 5:13 PM
    2015WhiteOR
    Gainesville TX
    I wouldn't worry.
  6. Mar 6, 2016 at 6:05 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    If you have factory tow package, you have aux cooler already. Save money and return aftermarket one, because factory one is a plenty.
  7. Mar 8, 2016 at 8:04 AM
    Highpowerrocket
    Thanks for the replies! I took the aftermarket one back and kept the stock one. It also has an oil cooler and some other upgraded features so I think I should be good.
    Now just need to get the trailer!
