Stock u-bolt size 99 5-lug
Discussion in '5 Lug' started by jrk, Feb 14, 2012.
  1. Feb 14, 2012 at 12:55 PM
    jrk
    jrk [OP] Active Member
    Does anyone know the stock u-bolt size on a 99 5-lug? The previous owner of my truck used lowering blocks to bring it down 3 inches in the rear.
    I want to remove these to raise it back up to stock height but the current u-bolts are too long (not to mention they are rusted and one is bent underneath the bolt).
    Does anyone know the size of the u-bolts I need to buy? Does it have to be exact or is it just anything that will fit the axle (which I believe is 2.75").
  2. Feb 14, 2012 at 3:05 PM
    87xjmike
    87xjmike Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
  3. Feb 15, 2012 at 6:20 AM
    jrk
    Thanks man...this is perfect.
  4. Feb 15, 2012 at 5:18 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    This^ axle tube is 3" and bolt size is 1/2
