Stock UCA Bolts/Nuts & Lower Strut Bolts/Nuts
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by goufcustom, Sep 15, 2012.
  1. Sep 15, 2012 at 8:17 AM
    goufcustom
    goufcustom [OP] 7.62x63mm
    MD
    2006 4x4 TRD Off Road DC SR5
    Bed Topper, Diff Breather, aFe Cold Air Intake, Satoshi Grill, Moved Horns, Oil Catch Can, Tailgate Lock, Husky Mud Flaps, H4 65/70W Bulbs, Lower Grill Mesh, TRD Skid Plate, LEDs in the bed, LEDs behind the grill for accent lighting, Parking lights as turn signals, LED turn signals and reverse lights, 5100s up front, eibachs up front, SS extended brake lines all around, 1.5" AAL in the rear, Relentless Fab U-Bolt Flip Kit, ICON Progressive AAL, TRD Wheel Center Caps, HomeLink, Heated Driver Seat, Hella 500 FF Driving Lights, BAMF Diff Skid, BAMF LCA Skids, BAMF Rock Sliders w/ KickOut.
    I have a set of factory (used) UCA Bolts, Nuts and Washers - $22 shipped to the lower 48 - OBO - SOLD
    I also have a set of factory (used) Front Lower Sturt Mount Bolts, Washers and Nuts - $5 shipped to the lower 48 - OBO
    These were on my truck, and I installed new LR UCAs, everything I read said to just cut these to get them out, well I didnt, and I had a new set from my stealership on hand, because they had to be ordered, and I didnt want my truck on jack stands over the weekend while I did this. Anyway, I installed the new parts because I had them, and my dealer would not take returns on the new parts because they were "Special Order". There is nothing wrong with these, if I hadnt bought the new ones I would have simply reused these.
  2. Sep 19, 2012 at 3:19 PM
    goufcustom
    MD
    Bump, anyone need these? Spare set for when you cut your bolts out to replace your UCAs and install them backwards from factory?
  3. Sep 19, 2012 at 3:24 PM
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    those are 4x4 uca bolts huh, just incase people were wondering lol
  4. Sep 19, 2012 at 3:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    IIRC, you can get those bolts for 6 bucks new.
  5. Sep 19, 2012 at 3:31 PM
    goufcustom
    MD
    Is there a difference between 4x4 and prerunner bolts?
    Stealership charges $16 per bolt, $3.50 per nut and not sure on the washers, where do you get them for that cheap?
    This is the best I could find - http://toyota-parts.toyotapart.com/search/index?query=90105-A0095&x=0&y=0 and then you add their $15 shipping cost in there and you make them just as much as from the stealership.
    Also, open to offers on them.
    These are the part numbers for the UCA bolt/nut, not sure what the number is for the washers.
    NUT - 90080-17208
    BOLT - 90105-A0095
  6. Sep 19, 2012 at 3:45 PM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    same part number in the catelog for 2wd and 4wd.
  7. Sep 20, 2012 at 2:12 PM
    jmarquez808
    Jess
    Hawaii
    07 4x2 reg cab
    i think 2wd should be different, the 4wd have the long bolts 2wd have two short bolts
  8. Sep 20, 2012 at 5:03 PM
    goufcustom
    MD
    The 6 Lug have 1 long bolt per side, and the 5 Lug have 2 short bolts per side.
    The 2 short bolts pictured are for front lower strut mounts on the 6 Lug.
  9. Sep 20, 2012 at 7:04 PM
    TRD6Speed
    Bill
    East Hartford, CT
    Feel like hooking me up for shipping? Karma is a awesome thing:D
  10. Nov 9, 2012 at 1:22 PM
    goufcustom
    MD
    Bump, still have these.
