Stock UCA rubbing springs, pass side only.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by whiskeytacos, Sep 6, 2015.
  1. Sep 6, 2015 at 8:56 AM
    whiskeytacos
    whiskeytacos [OP] Well-Known Member
    New York
    '14 DCSB Off Road MGM
    OME 886 springs on 90000 struts Total Chaos UCA OME Dakar + AAL energy suspension steering rack and sway bar bushings SCS SR8 wheels Cooper ST Maxx 285/85r16 Pelfreybilt IFS skid plate Pelfreybilt hidden winch mount broken ass winch Softopper All Pro Off Road OTT pack rack
    A few months back I installed Bilstein 5100's all around, with the front set at 1.75". It was fine installing them, got the truck aligned and was off to play. I had a few hard hits at the Silver Lake Sand Dunes in Michigan around July 4th, and other than a slightly bent off road package skid plate, I had no issues. There's one particular pot hole I pass on the way to work and I've nailed it a couple of times. About a month and a half ago my alignment seemed way off, and I unfortunately noticed it about an hour into a 4 hour drive upstate. The weekend after I got back home I had it aligned again (at a different shop, my regular mechanic this time) and the toe was way off on the driver side. There had also been a clunking I couldn't figure out from left turns at stop signs or lights, and sometimes over small bumps.
    Cut to today, when I'm installing my new Toytec springs and setting the 5100s back to 0. As I'm letting the front suspension back down to full droop, I hear a loud clank and start looking around. There's a big scrape on the brand new spring, and I notice the UCA is about two millimeters from rubbing on the springs. I grab the old factory spring and sure enough there's a divot. I figure, great, I need a new set of UCAs for a 1.6" lift. I button everything up, get the wheels on and prepare to go to my mechanic. The truck sat on the new springs for about 15 minutes while I cleaned up, and I took one last look before I left. After sitting on its own weight, everything shifted back into position. The UCA isn't rubbing anymore, in fact it has plenty of clearance and matches the driver side.
    I can only imagine the first guy that did my alignment did something wrong? No idea. Maybe it was the preload from the Billies on factory springs that had the UCA sitting way too close to the coils. Anyway, here are some pics. Divot is on the passenger side, the driver side pictured has no issues.
  2. Sep 6, 2015 at 11:03 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yup mine has this too. has nothing to really do with alignment. The stock UCA just doesnt have much clearance for the extra droop of the 5100's vs stock shocks. You can get lucky and spin the spring a bit to get it to where the UCA lip goes inbetween coil wraps. But in the end regardless of spring on the 5100, its the extra travel of 5100 and stock UCA that will make spring contact.
    There is a reason i have some SPC UCA's waiting to go on my truck.
  3. Mar 18, 2017 at 2:19 AM
    Trey51492
    Trey51492 Member
    Trey
    Mccalla, Alabama
    07 Silver DCSB 4x4 Tacoma
    OME 885, 5100 billies all around, Deaver AAL, 255/85R16 Cooper ST Maxx, Weathertech floor liners.
    I have this same issue. I installed 5100's and ome 885's and I need to spin the spring. Do I just loosen the 3 top nuts to spin?
  4. Mar 18, 2017 at 2:52 AM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    The three top ones are just to take off the coilover itself, and you can't spin the coilover 180 because the three bolts wouldnt line up anymore. if you want to spin the spring you need a compressor for the spring because you would need to untighten the single center nut but it's under pressure so dont do it without a spring compressor. (Insert personal sale lol) and if you need a spring compressor I am selling one here: https://www.tacomaworld.com/threads/pb-parts-for-sale.460769/ pm for shipping and ill get a price :thumbsup:
  5. Mar 18, 2017 at 5:35 AM
    Pigpen
    Dan
    Northwest Montana
    The stock UCA is the limiting factor for droop until you replace it. Your experience is normal - not ideal, just normal.
  6. Mar 18, 2017 at 5:41 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    I have 884's and 5100's with stock UCA. I don't think mine rub, at least I have not noticed anything.
  7. Mar 18, 2017 at 5:43 AM
    Pigpen
    Dan
    Northwest Montana
    At full droop they will rub.
  8. Mar 18, 2017 at 5:46 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    I got it now, bummer
  9. Mar 18, 2017 at 5:58 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    So, now I need to spend some more money. I don't do any heavy duty off-road, any recommendations for after market UCA,s or are they pretty much the same, Total Chaos ?
  10. Mar 18, 2017 at 8:07 AM
    doorsidedown
    doorsidedown Well-Known Member
    I have total chaos and love them. But for the price difference, light racing might be a better option if you don't offroad a lot.
    Lord Helmet and jwctaco[QUOTED] like this.
  11. Mar 19, 2017 at 9:45 AM
    tpotnoc
    tpotnoc Sit on my face
    Bellingham, WA
    15 2.7 DCSB PR
    Why bother?
  12. Mar 19, 2017 at 11:28 AM
    doorsidedown
    Should provide him some extra room so he doesn't rub the coils, allows for better alignment of lifted trucks, and makes room for more mods down the road - like performance coilovers.
  13. Mar 19, 2017 at 11:30 AM
    tpotnoc
    Bellingham, WA
    15 2.7 DCSB PR
    But if it only rubs at full droop, and he doesn't do much off-roading, just save the money. It's not going to improve anything at this point.
    Just my .02
    jwctaco likes this.
  14. Mar 19, 2017 at 11:31 AM
    doorsidedown
    True - that's why I steered him away from total chaos, UCAs are not absolutely necessary, I'm just too OCD to have rubbing that I can fix.
  15. Mar 19, 2017 at 1:28 PM
    Kbattlefield
    Kbattlefield Well-Known Member
    Kevin
    2015 metallic grey double cab TRD off-road
    As far as your question about UCAs- There are differences in aftermarket UCAs and pricing - ball joint versus uniball joint, etc. I just bought light racing UCAs and feel it's worth it for adjustability and increased articulation. Headstrong off-road is a great vendor to ask questions. The ones I got are low 400's$
  16. Mar 19, 2017 at 5:13 PM
    Trey51492
    Trey51492 Member
    Trey
    Mccalla, Alabama
    With the light racing uca being adjustable did you set the adjustment to where you wanted or did the alignment shop set the adjustment?
  17. Mar 19, 2017 at 6:05 PM
    Kbattlefield
    Kevin
    I haven't put mine on yet but you can do both. There are instructions for you to initially adjust them.
  18. Mar 21, 2017 at 1:45 AM
    whiskeytacos
    New York
    Talk about a thread revival. This is a couple of years old now and I'm currently running the same springs on 5100s but the shocks are set at .85" and I installed a set of Light Racing UCAs. I had an absolute nightmare of a time getting it properly aligned and finally went about an hour and a half away to another TacomaWorld member's shop.
    These trucks are weird, and no two are alike.
    My driver and passenger side caster settings are different on the UCAs, and we found that was the only way to get it aligned properly. I haven't had any rubbing issues since (except for full tuck on the sand dunes) and it drives great.
  19. Mar 21, 2017 at 1:57 AM
    Trey51492
    Trey51492 Member
    Trey
    Mccalla, Alabama
    Glad to hear it drives great! I just ordered a set of light racing UCAs from @HeadStrong Off-Road, I hope I have better luck with the alignment than you did lol.
    HeadStrong Off-Road likes this.
  20. Mar 21, 2017 at 2:01 AM
    whiskeytacos
    New York
    Nice! As long as you get it aligned by someone who understands custom suspensions, you should be alright. My first mistake was taking it to Toyota.
