stock UCA with coilovers?
Discussion in 'Suspension' started by derekAV, Dec 3, 2009.
  1. Dec 3, 2009 at 11:31 AM
    derekAV
    derekAV [OP] Well-Known Member
    derek
    Humboldt
    2000 4x4 reg. cab
    what would be the best set up if i want to keep my stock UCAs? i was thinkin the toytec coilovers set at around 3.?..and would i need to put limit straps?
  2. Dec 3, 2009 at 11:35 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The higher you lift the front end the harder it is to get enough caster in the alignment, which can cause the vehicle to wander on the freeway. Some people don't mind it and just run their factory UCAs. Limit straps are not necessary. For the new tacomas there are cheaper UCA options other than the Uniball style.
  3. Dec 3, 2009 at 1:47 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  4. Dec 3, 2009 at 1:49 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    If you want 3" you should get new uca's.
    Otherwise get the bilsteins for lift. Or OME coil lift. ~2"-2.5" is what you would want.
  5. Dec 3, 2009 at 5:18 PM
    derekAV
    derek
    Humboldt
    2000 4x4 reg. cab
    ok thanks guys :D appreciate it!
