Stock UCA's to Light Racing UCA's
Discussion in 'Suspension' started by raswank, Feb 9, 2011.
  1. Feb 9, 2011 at 10:48 AM
    raswank
    raswank [OP] Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    I noticed on the stock UCA's there are like hoses or lines bolted to them. I want the Light Racing UCA's, will they have the same bolt holes to connect them right back up? Thanks for your time, I have a chance to get a brand new set for 375.00 shipped with all hardware.
  2. Feb 9, 2011 at 10:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Those are wires for the abs sensor. If the LR UCAs don't have a hole foe the bolt, then you use a zip tie.
  3. Feb 9, 2011 at 11:27 AM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    i was able to unbolt the brackets off the stock uca's and the LR UcA'a have bolt holes to put the stock brackets on for brake lines etc......
  4. Feb 9, 2011 at 11:35 AM
    raswank
    Rick
    Auburn,Ma
    Niiiiiiiiccccccceeeeee thanks
  5. Feb 9, 2011 at 11:36 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    yea i have lr uca's and they have the holes for the bracket....
    g/l
  6. Feb 9, 2011 at 1:48 PM
    Valley Viking
    Valley Viking Well-Known Member
    Menlo, WA
    05 4x4 DC LB SR5
    OME 885 Coils, OME Dakar Rear Leafs, OME NitroCharger Shocks, LR UCA's, AFE ProDry Air Filter, Scanguage, Wet Okole Seat Covers
  7. Feb 9, 2011 at 1:59 PM
    raswank
    Rick
    Auburn,Ma
    Now that was awesome, thanks
  8. Feb 9, 2011 at 2:09 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    anyone know the size of the balljoint nut "socket size needed"
  9. Feb 9, 2011 at 3:43 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    Awesome, thanks for the video! Now how do I jack up my vehicle with a load on the suspension? Do I just put the bottle jack under the LCA, and take the wheel off?! That doesn't seem very safe...
  10. Feb 9, 2011 at 3:46 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    i suppoted the truck on jack stands the i slid the tire half under just as a precaution then jack form the lca
  11. Feb 10, 2011 at 10:14 AM
    Fabulous
    Fabian
    Calgary, AB
    How do you mean "slid the tire half under"? If I were to jack it up under the LCA, and then slip my jack stands under the frame I should be good no? I really only need the wheel about 1/2" off the ground to get it off...
  12. Feb 10, 2011 at 10:58 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    just when i take my tires off of the truck i slide them half under the truck incase anything ever happenes the frame will hang up on the tires.....
    thats just something i do.....
  13. Feb 10, 2011 at 10:59 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    loosen up your lugs
    jack up truck
    place jack stands on both sides of frame.....
    take tires off....
    slide them half under truck or sit on them...they make a good seat
    then you can use the jack under the lca if you need it there
  14. Feb 2, 2013 at 9:30 AM
    robjobu74
    robjobu74 Member
    CA
    08 PreRunner TRD Sport
    I used a floor jack but you can jack up and then put a jack stand under the frame to support then use the bottle jack to support under the brake caliper.
