Stock uca's with 2.5 inch lift and 33s?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wilgray2010, Aug 10, 2015.
  1. Aug 10, 2015 at 3:02 PM
    Wilgray2010
    Wilgray2010 [OP] Well-Known Member
    Northbridge, MA
    01 2.7 5spd
    Billy 5100s, 20% tint, s13we tundra calipers/rotors, super turbo muffler
    I have a 01 single cab with the billy 5100s and want to install a 1.5 inch body lift so i can fit 33s. Right now im running 265/75/16 with the stock uca's and my alignment is within the spec. If i upgrade to the 33/12.5/15 will i need adjustable uca's even tho I'm not going any higher with the suspension?
  2. Aug 10, 2015 at 4:25 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    going with a bigger tire wont affect alignment or suspension lift. 33s will fit without the body lift with mild trimming.
  3. Aug 10, 2015 at 6:02 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Yeah a body lift has absolutely no bearing on suspension components, regardless of tire size.
  4. Aug 10, 2015 at 6:35 PM
    Wilgray2010
    Northbridge, MA
    01 2.7 5spd
    I guess what I'm trying to ask is will they be able to get the camber within the spec if i get a wider tire with out the adjustable uca's
  5. Aug 10, 2015 at 6:37 PM
    bry838
    oregon
    Yes, no issue on that at all.
    Usually the rule on getting uni ball uca's to get alignment in spec when you get up to a true full three inches of suspension lift. (Excluding a drop bracket lift, cause with that setup the suspension is still in its stock "geometry")
  6. Sep 3, 2015 at 5:12 PM
    killa taco
    killa taco Killa Taco
    Ricky
    La Puente
    2007 tacoma prerunner double cab short bed
    Toytec blistein adjustable lift kit eibach springs with add a leaf in back 265/75/r16 cooperATP AT
    Quick question if I add 33s do I need to regear I want to go to a 4inch lift and add 285/65r18 or 33x12.5r20 I like the 33s but not sure if my truck will still run good also not sure if to do 4inch all around or do 5-6inch in the front and 4inch in the rear
  7. Sep 4, 2015 at 3:06 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Yes you'll need to re-gear. If not, the acceleration you once had will be but a memory.
    I went from OEM 265-70-16's to 285-75-16's. My gear ratio is now 5.29's.
    I have the 2.7 motor and an auto trans. All works well.
    To set the speedo, I used a Dakota Digital device to get it right on the money.
    Hope this helps you.
  8. Sep 4, 2015 at 3:20 PM
    killa taco
    Ricky
    La Puente
    What gears you think I would need to get and I got. A V6 4.0 that wouldn't be able to handle it? Just want to make sure.. cuz i want to go bulkier also 305/55r20s r another choice I have there in the middle of the 285s n 33x12.5
  9. Sep 4, 2015 at 3:29 PM
    Ritchie
    I suggest more research on your part.
    I have an '03... going with 285's I needed a 1/2" spacer to clear to uni-ball on my UCA. No cutting or pinch weld mod.
    For your year, I can tell you there will be some cab mount mod's made to clear the 285's. For 305's, I'm sure there will be that mod and more.
