Stock wheel big tire
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Baldi13, Sep 3, 2018.
  1. Sep 3, 2018 at 2:29 PM
    Baldi13
    Baldi13 [OP] New Member
    2016 Tacoma TRD sport arctic white
    Stock
    Hey people question for you. I'm looking to upgrade my tires I was told on the stock wheel I can go as big as a 275/70R17. Any input would be great. I want to stay with the stock wheel and go big with the rubber. If I need to I will delete the mud flaps. TIA.
  2. Sep 3, 2018 at 2:31 PM
    Taylorbarton1
    Taylorbarton1 Well-Known Member
    Taylor
    Hotlanta
    2011 TRD off-road
    6 inch lift. 35's.
    For what it's worth I'm running a 315 75r16 on stock trd O/R wheel. I don't see any issues with your desired setup.
  3. Sep 3, 2018 at 2:31 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The widest you can go is 265. Any wider and you will rub the UCA unless you run wheel spacers. You can go 255/80r17 which is a 33" tire. You'll also have minimal rubbing with that size.
  4. Sep 3, 2018 at 2:35 PM
    Baldi13
    Stock
    So going with a 255/80r17 will rub a bit. But what if I didn't want to go to an 80. I would really like a 285/70r17. I want it wider and a bit taller.
  5. Sep 3, 2018 at 2:37 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The first number in tire size is width, with the second just aspect ratio. any wider than 265 and you will need either rub your UCA (upper control arm) or you'll need some wheel spacers.
    Here's a comparison of the two sizes.
  6. Sep 3, 2018 at 2:40 PM
    Baldi13
    Stock
    Ok next what size spacers would I use to get a wider taller tire under the truck?
  7. Sep 3, 2018 at 2:42 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Bora makes spacers starting at 0.75"-2". If you want bigger and wider, I would recommend 285/70r17 with some 1" spacers. You'll need to lose mudflaps, trim some plastic in the wheel well, and maybe a can mount chop (CMC).
