Stock wheel stud specs
Discussion in 'Technical Chat' started by rodstone, Feb 15, 2010.
  1. Feb 15, 2010 at 12:59 PM
    rodstone
    rodstone [OP] Well-Known Member
    Travis
    California
    08 2.7l 2wd
    I have a 08 5lug and want/need to switch out the stock wheel studs for some that are 8mm or 5/16" longer. I just need to know what the specs are of the stock ones (knurl length, knurl dia., thread length). I know they are 12x1.5. TIA for any input.
  2. Feb 15, 2010 at 1:09 PM
    07tacoswb
    07tacoswb Well-Known Member
    Alan
    North Carolina
    16 Tundra CrewMax XSP-X
  3. Feb 15, 2010 at 6:47 PM
    rodstone
    Travis
    California
    08 2.7l 2wd
    Thank you very much!!! Exactly what I was looking for!!:thumbsup:Thanks again!!!
  4. Feb 16, 2010 at 7:43 AM
    07tacoswb
    Alan
    North Carolina
    No Problem. I didn't like the amount of thread left after installing my new wheels which was about a 1/4". I feel very comfortable with them now being about 1/2" longer than before makeing them about 3/4". And you don't have to use a special tool to install them. I used a hammer to remove the old studs and I used 5 heavy duty washers and a lug nut to install the new ones. You put the new stud in and place the washers over it and then screw on the lug nut. Then I used my impact gun to run the lug nut tight and it pulled each one up tight with out a problem.
