Stock Width Replacment LCA
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blackdawg, Sep 23, 2015.
  1. Dec 12, 2015 at 7:27 PM
    #181
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    http://dictionary.reference.com/browse/gem
    noun
    1.
    a cut and polished precious stone or pearlfine enough for use in jewelry.
    2.
    something likened to or prized as such astone because of its beauty or worth
    Just trying to help out my fellow TW members.:D
    jberry813[QUOTED] likes this.
  2. Dec 12, 2015 at 7:42 PM
    #182
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    I thought about building uniball stock length lowers for the 1st gens like 3 years ago. After toying with them for a bit I decided it just wasn't worth it so I plated up the stock ones (which Jason posted pictures of a few pages back) really the only problem with stock lowers is the bushings and with arms being so cheap it just didn't make sense. And I really didn't see a reason to go uniball, the stock ball joints don't fail often. Uniballs are a lot larger than the ball joints and with the lower arm adapter with the steering arm it just didn't fit without changing the geometry.
    Now as far as vertical uniballs. They wear out faster end of story. That's not a problem if you run them on the upper because it sees very little force. But the lower sees all the force and the lower is longer so it's never the limiting factor so I have never seen a reason to run a vertical lower uniball.
    jberry813 likes this.
  3. Dec 12, 2015 at 7:54 PM
    #183
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    No. Does not make sense. It seems to me that there is more force up and down as the suspension cycles. Also, I thought a asked for a truly knowledgeable asshole to answer, and it's nearly impossible to so much as approach Jason's level on that matter.
    Need to revise you statement Monte?
  4. Dec 12, 2015 at 8:00 PM
    #184
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Just so we are clear, a vertical uniball means the bolt is horizontal.
  5. Dec 12, 2015 at 8:03 PM
    #185
    Squeaky Penguin
    Brett
    :anonymous:
    :thumbsup:
    Carry on,
  6. Dec 12, 2015 at 8:06 PM
    #186
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    But what do I know.
    Squeaky Penguin likes this.
  7. Dec 12, 2015 at 8:12 PM
    #187
    Squeaky Penguin
    Brett
    Hopefully more than me.
  8. Dec 12, 2015 at 8:23 PM
    #188
    Supermoto
    Landon
    Fallbrook
    And just the clarify most of the stress applied to a lower spindle pivot is vertical. The horizontal force is mostly applied to the inner pivots on the arm
  9. Dec 12, 2015 at 8:28 PM
    #189
    jberry813
    Lake Tahoe
    2012 DCSB Sport
  10. Dec 12, 2015 at 10:48 PM
    #190
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No..I don't think so. Pretty sure I'm correct on my points..
    Either way. It would be cool to have a stock are even with the stock ball joint adapter. But only if secondary's mounts and maybe stike pads and limit strap points are part of it.
  11. Dec 12, 2015 at 10:57 PM
    #191
    Supermoto
    Landon
    Fallbrook
    You really don't need to worry about strike pads. This has been gone over a thousand times, an air bump puts less stress on the arm than a rubber bump does. I've built many trucks with an air bump hitting where the stock bump did on a stock lower arm and never had a problem. My brothers Tacoma has been setup this way for 6 years.
  12. Dec 13, 2015 at 11:09 AM
    #192
    Blackdawg
    Monte
    Wyoming/St. Louis
    Interesting. Didn't know that
  13. Dec 13, 2015 at 12:42 PM
    #193
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Fair enough.
    I haven't followed long travel stuff since around 01 so I checked out that design and reread your OP. All I really see to date is essentially a $1200+ uniball conversion.
    Outside of Mr jberry's comment on the ball orientation and the LT version shown using a rod end for steering (included with stock length kit?). I see further things that may or may not warrant some discussion. I'm going by the (2013) pic of the adapter so if it is changed I will stand corrected.
    First, it almost looks like a "proof of geometry" non structural mock up. I'm referring mostly to the circular cut out in the upper plate where the 4 spindle mount bolts are and the cut out being open on the inboard side. This leaves the inner two bolts doing very little and this junction needs to have everything possible going for it. I am assuming the cut out is to allow the ball to be up close to the bottom of the spindle, trading off some strength for ground clearance underneath the whole thing, just a guess there.
    Second, the strength of the lower end of the stock spindle was questioned in the long travel thread but quickly dismissed. I am of the opinion that the relatively massive 5/8"+ thick OEM joint bolted to the bottom of the spindle adds a significant amount of strength and stability in that area and is actually a needed structural component of the spindle. Then there is the issue of the spindle having only 4-5 useful threads on the inboard 2 bolt holes.
    Third, on an OEM joint the outer 2 mount bolts run through sleeves/locating dowels that contribute a bunch to strength. The pic isn't very clear but it looks like the adapter has just 4 holes.
  14. Dec 13, 2015 at 12:49 PM
    #194
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea ive never seen the kit in person so I couldn't really comment on it. That and I think he has made only two. Not really sure about that either.
    One thing I've thought about especially ever since my boots sheared off is I wonder if it would be possible to machine down the tops of the holes on the two inboard bolts to add longer bolts and nuts too. Since they poke out already. Kinda over kill I think as I've never had an issue with bolts since red loctite goes on all of mine every time they come out now but still a thought.
    You are right though on how the thickness is probably a large contributing factor and the sleeves.
    All things to consider if trying to make a unibal conversion. Which at this rate I don't see it happening anyways.
  15. Jan 15, 2016 at 9:06 AM
    #195
    2scars
    2scars Swollen Member
    Brandon
    RVA
    2003 TRD 4x4 Doublecab
    All-pro, T-G, Budbuilt, Warn, Tepui, Homefab rear bumper
    Do you think Delrin would hold up to the task? If so I may have some spun up locally. My truck is a DD with baby carrying duty. MUST be safe.
  16. Jan 15, 2016 at 12:42 PM
    #196
    Blackdawg
    Monte
    Wyoming/St. Louis
    It is very very hard and also brittle though. For a DD, i don't see the need for it since its so expensive when there are poly ones readily available. Poly would be fine.
  17. Jan 22, 2016 at 7:02 AM
    #197
    2scars
    Brandon
    RVA
    Roger that^^^^
  18. Apr 15, 2016 at 8:26 AM
    #198
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Is it possible to add for some additional caster in the design or can that only be done in the UCA? I just had my alignment done with Total Chaos UCA and I'm having trouble hitting spec. Granted the bed/spare is off currently but it doesn't look like 2 or 3 degrees is in my future.
  19. Apr 15, 2016 at 10:41 AM
    #199
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    @alphabravo
    I thought you just did the new whiteline bushings and new cam bolts in your LCAs?
    It seems like 3* of caster should be easy to attain on your setup, assuming your LCA cam bolts are not frozen. FWIW, the Camburg/Total Chaos unibal arms dial in +2* by themselves.
    Are you certain the alignment tech tried adjusting from the lower cam bolt adjusters?
  20. Apr 15, 2016 at 12:57 PM
    #200
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    @Digiratus
    Yep. TC UCAs and Whitelines. On of the local guys here works at a dealership and let me watch while he did the alignment. I'm pretty sure he worked all four lower cams plus the tie rod ends.
    1. They have an older system and it only let him enter stock size tires (265/65R16 I think). I am running 265/75R16. I'm not sure how this would affect the alignment.
    2. ADS coilovers are set at about 0.5" (passenger) to 1" (driver) which translates to about 2" of lift.
    3. The only weight I have in the back is the plate bumper. The bed and spare are off. Plus the Deaver Expos all give me a pretty mean rake with prolly over 3.5" of lift. I'm thinking that this is what is killing my caster. If not then I'm not sure why I can't hit spec on caster (about 1.3* or less vs spec at 1.8*).
